Lian Li Factory Tour: Only Ever Aluminium
August 24, 2010 | 10:11
Tags: #aluminium #case #chassis #factory #factory-tour #laser-cutter #taipei
Companies: #lian-li #taiwan
Putting together and packing up
A short hop upstairs and there's a couple of lines for construction and packing. Here all the panels get put together, the fans get dropped in - and tested - and it then gets boxed up ready to be shipped out.
Lian Li doesn't keep a lot of spare stock - items are generally made to order as the company can turn around between 600-1,000 cases a day.
Lian Li Factory Tour: Only Ever Aluminium Lian Li Factory Tour: Putting together and packing up
The large upper floor is where the real cases are born. Aww.
Lian Li Factory Tour: Only Ever Aluminium Lian Li Factory Tour: Putting together and packing up Lian Li Factory Tour: Only Ever Aluminium Lian Li Factory Tour: Putting together and packing up
All the separate parts finished downstairs get moved upstairs on pallets: here all the parts of the PC-C50 HTPC case get put together.
Zipped up and good to go!
And a big thanks to Lian Li for showing us around! If you've got any comments, feel free to drop them in the forums!
