Lian Li PC-V358 Review - Cooling Performance
Due to the fact our usual micro-ATX cooler won't fit in the Lian Li PC-V358, we clearly weren't able to add our results to our usual micro-ATX case graphs. However, we did have another way of comparing it to a bunch of other small cases, which was to use our mini-ITX test gear that uses a low profile cooler. This means that comparisons can only be made against the results in the graphs - not with any other micro-ATX case results.
Our test kit includes:
- CPU: Intel Core i5-2500K overclocked to 4.3GHz using a vcore of 1.3V.
- Graphics card: GeForce GTX 570 1.3GB
- Motherboard: Asus P8Z77-I Deluxe
- RAM: 4GB Kingston DDR3 1600MHz memory
- PSU: Enermax Eco 82+ 620W PSU
- CPU cooler: Zalman CNPS 8900 low-profile cooler
The graphics card fan was locked at 70 per cent speed and the system was loaded using Prime95 and Unigene's Heaven benchmark. We used Realtemp and GPU-Z to monitor the temperatures, taking the maximum values when the readings had plateaued.
Silverstone Sugo SG08 (High Speed)
BitFenix Prodigy
Silverstone Sugo SG08 (Low Speed)
Silverstone FT03-Mini
Fractal Design Node 304 (High Speed)
Cooler Master Elite 130 Advanced
Lian Li PC-TU200
Lian Li Lian Li PC-Q28
Lian Li PC-V358
EVGA Hadron Air
BitFenix Phenom
Cooler Master Elite 120 Advanced
Fractal Design Node 304 (Low Speed)
°C, lower is better
BitFenix Prodigy
Fractal Design Node 304 (LowSpeed)
Lian Li PC-V358
EVGA Hadron Air
BitFenix Phenom
Lian Li PC-Q28
Lian Li PC-TU200
°C, lower is better
