Cooling Performance
For cases capable of housing ATX or larger motherboards, we use our standard ATX case test kit, which includes:
We disable the motherboard's onboard CPU fan control and all CPU power management features. The CPU fan is fixed at 7V with an adaptor while the graphics card fan is locked at 70 percent speed using MSI Afterburner. The system is loaded using Prime95 25.11 and Unigine's Heaven 4.0 benchmark. We use Core Temp and GPU-Z to monitor the temperatures, taking the maximum values after 15 minutes - enough time for the readings to plateau.
Lian Li PC-D888 (8 x 120mm fans; max speed)
NZXT Noctis 450 ROG
In Win 509 (140mm rear fan)
SilverStone Primera PM01
Thermaltake Tower 900
Phanteks Enthoo Pro M Tempered Glass
SilverStone Raven RVX01
Be Quiet! Pure Base 600 (max speed; ventilated)
Corsair Crystal Series 570X RGB
NZXT S340 Elite
BitFenix Aurora
Cooler Master MasterCase Pro 5
Lian Li PC-D888 (8 x 120mm fans; min speed)
Be Quiet! Dark Base Pro 900 (inverted ATX)
Cooler Master MasterCase Maker 5t (max speed; ventilated)
Corsair Crystal Series 460X RGB
In Win 303
Nanoxia Project S
Cooler Master MasterCase Maker 5t (max speed)
Cooler Master MasterCase Maker 5t (min speed)
Corsair Carbide Series 270R
No case - open test bench
Be Quiet! Pure Base 600 (max speed)
Cooler Master MasterBox 5t (max speed)
Corsair Carbide Series 600C (max speed)
Nanoxia CoolForce 1 (max speed)
Aerocool DS 230
Be Quiet! Dark Base Pro 900 (max speed)
Be Quiet! Pure Base 600 (med speed)
Be Quiet! Silent Base 600 (max speed)
Corsair Carbide Series 400C
Corsair Carbide Series 600C (med speed)
Corsair Carbide Series 600C (min speed)
In Win 805
Nanoxia CoolForce 1 (med speed)
Be Quiet! Dark Base Pro 900 (min speed)
BitFenix Pandora ATX
Cooler Master MasterBox 5t (min speed)
Nanoxia CoolForce 1 (min speed)
Phanteks Eclipse P400S (max speed)
Be Quiet! Silent Base 600 (med speed)
BitFenix Nova
Be Quiet! Pure Base 600 (min speed)
In Win 509 (stock - no fans)
Be Quiet! Silent Base 600 (min speed)
Phanteks Eclipse P400S (med speed)
Lian Li PC-D888
Phanteks Eclipse P400S (min speed)
°C (lower is better)
NZXT Noctis 450 ROG
NZXT S340 Elite
In Win 303
Lian Li PC-D888
BitFenix Aurora
In Win 805
Aerocool DS 230
Nanoxia Project S
BitFenix Nova
°C (Lower Is Better)
