The GPU delta T was only 5°C off the best result at 49°C, which was again close to the View 37 RGB and actually a fair bit better than the Corsair 460X. Clearly, if you do go for an air-cooled PC (or just need time to save up for a full loop) the layout here will stand you in good stead, so the only real issue you'll have is dust - it'll need semi-regular maintenance to keep things looking fresh.
If you have the space for Thermaltake's Core P90, it's definitely a high-ranking contender for those that want the biggest and best in terms of showing off your hardware. It is a little ungainly in areas, but its real competition comes from Thermaltake's other Core cases, namely the Core P3 and Core P7. The former is considerably cheaper but can still house a high-end water-cooled ATX system, while the Core P7 costs around £80 more but offers a huge amount more potential for showing off with its fold-out arms. This leaves the aptly-named Core P90 in a slight middle-ground quandary. If you must have an open-air show case, though, the Core P90 still comes highly recommended and has the additional horizontal placement orientation which might tempt you away from Thermaltake's other Core cases.
