Deus Ex: Mankind Divided
Publisher: Square Enix Holdings
We test using the 'Ultra' preset and at these settings it is currently one of the toughest games to run smoothly, presenting a challenge for even flagship graphics cards. We run the built-in benchmark (hidden in the 'Extras' menu) as it is very consistent and makes full use of the engine's features. We also rely on the game's own frame rate counter since FRAPS does not currently work with this game when using DirectX 12. We've actually found that your experience in-game will typically be with frame rates actually a little higher than the average frame rate from the benchmark, but even so it's the minimum frame rate that we focus on and that you should really take into consideration because it's in the most challenging parts of the game that you'll really feel the slowdowns, and it's no good having a sub-par experience in the heat of battle.
EVGA GeForce GTX 1080 FTW 8GB
Overclockers UK Titan Osprey
Corsair One Pro
Palit GeForce GTX 1070 GameRock Premium Edition 8GB
The PC Customiser Venom VR Powered by Gigabyte
PC Specialist Magma Zen
Sapphire Radeon RX 480 Nitro+ OC 8GB
Sapphire Radeon RX 480 Nitro+ OC 4GB
Nvidia GeForce GTX 1060 Founders Edition 6GB
Sapphire Radeon RX 470 Nitro+ OC 4GB
Gigabyte GeForce GTX 1060 WindForce OC 3GB
MSI GeForce GTX 1050 Ti Gaming X 4GB
Frames Per Second
Corsair One Pro
Frames Per Second
Fallout 4
Publisher: Bethesda Softworks
Our Fallout 4 benchmark is a 30-second FRAPS recording of a manual playthrough, where our character runs forward through a woodland area just outside the Corvega Automation Plant. The scene is very challenging relative to the rest of the game, with massive draw distances and complex volumetric lighting. This means the results below are not representative of typical gameplay, but rather of the most challenging points in the game. We test at the game's 'Ultra' preset, the highest available, and v-sync is disabled in the game's .ini file.
DinoPC C3 Mod Gaming PC
Corsair One Pro
20
30
40
50
60
70
80
Frames Per Second
Corsair One Pro
Frames Per Second
3DMark
Publisher: Futuremark
3DMark is arguably the most popular synthetic benchmark around today. The DirectX 11 portion, Fire Strike, comes in three flavours: Fire Strike, Fire Strike Extreme and Fire Strike Ultra, which run at 1080p, 1440p and 4K respectively. All products are tested in Fire Strike using the default settings, as anyone can download and run this exact benchmark for free, so you can easily compare your own system's score with those you see below. More powerful products are tested in Fire Strike Extreme and Fire Strike Ultra as appropriate, but you'll need to pay to unlock these benchmarks yourself.
3DMark also recently added Time Spy, a DirectX 12 benchmark that runs at 1440p. It is designed to properly utilise the advantages of the DirectX 12 API. The benchmark is available for free, but you'll need to pay to change any of the settings, including the resolution. Nonetheless, it still serves as a useful at-a-glance comparison of performance in this increasingly important API.
Corsair One Pro
Gigabyte GeForce GTX 950 OC 2GB
Gigabyte Radeon RX 460 WindForce 2X OC 2GB
Score
Corsair One Pro
Score
Corsair One Pro
2000
3000
4000
5000
6000
7000
8000
Score
VRMark
VRMark is another synthetic GPU benchmark from Futuremark, this time specifically designed to assess a system's ability to handle VR gaming, with no VR headset is required. The Orange Room test assesses whether a system is capable of meeting the current minimum requirements for an Oculus Rift or HTC Vive VR headset. We run the test with its default settings, so users can easily compare scores here to the free version of this benchmark where settings cannot be changed.
Corsair One Pro
Oculus Rift Minimum
5000
7500
10000
12500
Score
