In low resolution tests the difference between XMS2-9136 and XMS2-10000 is on average a single frame per second. The difference between motherboards is also greater than the difference between DDR2-800 and that of the highest possible clock attained.
In high resolution tests, we encountered the same scenario as with the XMS2-9136 modules: the limitation is graphics before CPU and memory making the difference even less pronounced.
