OpenCL and OpenGL Performance
We're introducing some OpenCL/OpenGL benchmarks to our test suite to coincide with the Kaveri launch, as they are important and steadily growing open source platforms that are especially relevant to APUs due to the focus on GPU acceleration. Please note that we've only had a chance to test the most relevant processors in these new tests. Also, these are not OpenCL 2.0 benchmarks, and as such none of them are optimised to take advantage of AMD's HSA features.
MuseMage 1.9.6
Website: www.musemage.com
MuseMage is a GPU accelerated image editing software with plenty of advanced features and batch processing. It has a built in benchmark that applies a series of effects and filters to an image in quick succession, awarding a linear score based on completion time.
        AMD A10-7850K (4.4GHz)
        AMD A10-7700K (4.3GHz)
        AMD A10-7850K (3.7GHz)
        AMD A10-7700K (3.4GHz)
        AMD A10-6800K (4.1GHz)
        AMD A8-7600 (3.3GHz) (65W TDP)
        AMD A8-7600 (3.1GHz) (45W TDP)
        AMD A8-6500T (2.1GHz)
        Intel Core i3-4330 (3.5GHz)
            6433
            6113
            5546
            5180
            5063
            4966
            4595
            3335
            1862
          2000
          3000
          4000
          5000
          6000
          7000
    Points (higher is better)
LuxMark 2.0
Website: www.luxrender.net
LuxMark 2.0 is an OpenCL benchmarking tool for LuxRays, the ray tracing component of the LuxRender suite. It can be set to run its highly parallel OpenCL workload on the CPU, GPU or both at once in one of three scenes of various complexity. We benchmark the Sala scene (medium complexity) and scores are reported in thousands of samples per second.
          200
          300
          400
          500
          600
          700
    Thousands Of Samples Per Second (higher is better)
CPU only
GPU only
CPU and GPU
Rightware BasemarkCL 1.1
Website: www.rightware.com
BasemarkCL is a comprehensive OpenCL and OpenGL benchmarking suite from Rightware that runs a series of heavy parallel workloads, from image manipulation techniques like smoothing and noise reduction, to fluid and wave simulations as well as ray tracing and fractal rendering. We run the entire suite on the GPU portion of a chip and report the final overall score.
            97.184
            85.123
            73.632
            65.173
            63.805
            57.612
            48.694
            44.017
            37.106
