Power Consumption
For all of the performance tests, we disable all power-saving technology in order to give us a consistent set of results, and to give us best-case performance numbers - even though technologies such as Intel's SpeedStep might only take microseconds to kick in, that can make a difference in some tests.
However, for the power consumption tests we re-enable everything in order to gauge real-world power draw. The power draw is measured via a power meter at the wall, so the numbers below represent the total system power draw from the mains, not the power consumption of a CPU itself. Measuring the power draw of any individual component in a PC is tricky to impossible to achieve.
Idle Power Consumption
For this test, we leave the PC doing nothing but displaying the Windows 7 desktop (with Aero enabled) for a few minutes and record the wattage drawn from the wall via a power meter.
AMD A10-6700 (3.7GHz)
AMD A8-6500T (2.1GHz)
AMD A10-5700 (3.4GHz)
AMD A10-6800K (4.1GHz)
AMD A10-5800K (3.8GHz)
Intel Core i3-4330 (3.5GHz)
Intel Core i3-2100 (3.1GHz)
AMD A8-7600 (3.1GHz) (45W TDP)
Intel Core i3-3220 (3.3GHz)
AMD A8-3850 (2.9GHz)
AMD A8-7600 (3.3GHz) (65W TDP)
AMD A8-3870K (3.0GHz)
35
35
36
36
36
38
40
46
46
47
47
47
Watts (lower is better)
Load Power Consumption
To generate a realistic load power consumption figure we need to load both the CPU and GPU portions of the processors. To do this we use Prime95 to load the CPU and Unigine's Heaven benchmark to load the GPU.
76
78
83
84
90
96
107
109
140
145
158
158
50
75
100
125
150
175
