Media Benchmarks
Download from: bit-tech.net
We've developed our own suite of benchmarks using real-world and open-source applications to simulate how PCs are actually used. The suite comprises an image editing test using Gimp, a video encoding test using Handbrake, and a multi-tasking test using 7-Zip to archive and encrypt a large batch of files while an HD movie plays in mplayer.
A score of 1,000 means that the test system is as fast as our reference PC, which used a 2.66GHz Intel Core 2 Duo E6750 at stock speed, 2GB of Corsair 1,066MHz DDR2 memory, a 250GB Samsung SpinPoint P120S hard disk and an Asus P5K Deluxe WiFi-AP motherboard. The scoring system is linear, so a machine scoring 1,200 points is 20 per cent faster than our reference system. Equally, a system scoring 1,200 is 4 per cent faster than a system scoring 1,150.
Multi-tasking with 7-Zip and mplayer
Websites: www.7-zip.org and www.mplayerhq.hu
Multi-tasking is a phrase with which we're all familiar, as most of us are now used to running multiple applications at the same time. However, to run multiple applications well you need a powerful (ideally multi-core) CPU and plenty of RAM.
Our multi-tasking test performs a massive file backup (with encryption) using 7-Zip, while simultaneously playing back an HD movie file using mplayer, making it a demanding test for any PC.
Multi-tasking
Applications: mplayer, 7-Zip
  • Intel Core i5-2400 (3.1GHz)
  • Intel Core i3-3220 (3.3GHz)
  • Intel Core i3-4130 (3.4GHz)
  • Intel Core i3-4330 (3.5GHz)
  • Intel Core i3-2100 (3.1GHz)
  • AMD A10-6800K (4.1GHz)
  • AMD A10-6700 (3.7GHz)
  • AMD A10-5800K (3.8GHz)
  • AMD A10-5700 (3.4GHz)
  • AMD A8-6500T (2.1GHz)
  • AMD A8-7600 (3.3GHz) (65W TDP)
  • AMD A8-7600 (3.1GHz) (45W TDP)
  • AMD A8-3870K (3.0GHz)
  • AMD A8-3850 (2.9GHz)
  • 1494
  • 1410
  • 1320
  • 1235
  • 1141
  • 1122
  • 1089
  • 1071
  • 1039
  • 924
  • 883
  • 853
  • 768
  • 757
500
750
1000
1250
1500
Points (higher is better)
Overall Score
The overall score is an unweighted mean average of the scores of the three individual tests. A score of 1,000 means that the test system is as fast as our reference PC, which used a 2.66GHz Intel Core 2 Duo E6750 at stock speed, 2GB of Corsair 1,066MHz DDR2 memory, a 250GB Samsung SpinPoint P120S hard disk and an Asus P5K Deluxe WiFi-AP motherboard. The scoring system is linear, so a machine scoring 1,200 points is 20 per cent faster than our reference system. Equally, a system scoring 1,200 is 4 per cent faster than a system scoring 1,150.
Overall Score
Applications: Gimp, Handbrake, mplayer, 7-Zip
  • 1850
  • 1826
  • 1788
  • 1694
  • 1476
  • 1447
  • 1395
  • 1366
  • 1358
  • 1272
  • 1244
  • 1082
  • 1059
  • 1001
1000
1500
2000
