Cinebench R10 64-bit
Download from: www.maxon.net
Cinebench R10 uses Maxon's Cinema 4D engine to render a photo-realistic scene of a shiny motorbike. The scene is highly complex, with reflections, ambient occlusion and procedural shaders so it gives a CPU a tough workout.
The test can be in run in single-threaded 1CPU mode or multi-threaded xCPU mode - just click the respective button. In this way, Cinebench R10 is useful for gauging the performance of each execution core of a CPU, as well as its overall performance.
As Cinema 4D is a real-world application - used on films such as Spider-Man, Star Wars among others - Cinebench R10 can be viewed as a real-world benchmark.
        Pentium Dual Core E5200 (2x4.0GHz, 1,333MHz FSB)
        Athlon II X2 250 (2x3.8GHz, 2.4GHz NB, 2.0GHz HTT)
        Athlon X2 7850 BE (2x3.1GHz, 2.0GHz NB, 2.0GHz HTT)
        Athlon II X2 250 (2x3.0GHz, 2.0GHz NB, 2.0GHz HTT)
        Athlon X2 7850 BE (2x2.7GHz, 1.8GHz NB, 2.0GHz HTT)
        Athlon X2 6000+ (2x3.4GHz, 1.1GHz HTT)
        Pentium Dual Core E5200 (2x2.5GHz, 800MHz FSB)
        Athlon X2 6000+ (2x3.1GHz, 1.0GHz HTT)
            4641
            4302
            3350
            3300
            3030
            3009
            2950
            2744
          2000
          3000
          4000
          5000
    Score - higher is better
        Athlon II X2 250 (2x3.9GHz, 2.4GHz NB, 2.0GHz HTT)
            8778
            8396
            6678
            6531
            5898
            5883
            5673
            5291
          2000
          3000
          4000
          5000
          6000
          7000
          8000
          9000
At its stock clock the Athlon II X2 250 is faster than any other stock clocked CPU at this price point. Clearly its extra frequency gives it an advantage in this test. Even when overclocked, the Athlon X2 7850 BE is barely any faster than the Athlon II X2 250, and once the latter is overclocked it trounces the more expensive Athlon processor. The same goes for the Pentium E5200 though, which outperforms every CPU when overclocked. Although the Athlon II X2 250 gives it a great run for its money, there's still several hundred points between them.
