CustomPC Media Benchmarks
Download from: www.custompc.co.uk/benchmarks
Custom PC,
bit-tech's sister magazine, has developed its own Media Benchmarks to simulate the tasks that most of us perform on a regular basis. There are three tests, each of which measure different aspects of a PC's performance.
You can download the suite from the link above, and submit your score to the benchmark leaderboard to see how your PC compares with those of others.
GIMP Image Editing
        Pentium Dual Core E5200 (2x4.0GHz, 1,333MHz FSB)
        Athlon II X2 250 (2x3.9GHz, 2.4GHz NB, 2.0GHz HTT)
        Athlon X2 7850 BE (2x3.1GHz, 2.0GHz NB, 2.0GHz HTT)
        Athlon II X2 250 (2x3.0GHz, 2.0GHz NB, 2.0GHz HTT)
        Pentium Dual Core E5200 (2x2.5GHz, 800MHz FSB)
        Athlon X2 6000+ (2x3.4GHz, 1.1GHz HTT)
        Athlon X2 7850 BE (2x2.7GHz, 1.8GHz NB, 2.0GHz HTT)
        Athlon X2 6000+ (2x3.1GHz, 1.0GHz HTT)
            270
            309
            395
            398
            421
            426
            436
            452
    Seconds - lower is better
Again the Athlon II excels itself compared to previous AMD CPUs, as it's a significant 28 percent faster than the Phenom X2 7850 BE, and even outperforms the E5200 at stock speeds by 25 seconds, it's nearly 40 seconds behind when both CPUs are overclocked.
Handbreak x.264 Video Encoding
            552
            593
            747
            760
            807
            837
            855
            865
          200
          300
          400
          500
          600
          700
          800
          900
Again, the overclocked Intel E5200 claims the lead here, but only by seven percent over the overclocked Athlon II. Both CPUs are a significant way ahead of the rest of the pack though, which sit much closer together. At stock speeds the Athlon II is the clear leader though, as it even outperforms the
overclocked 7850 BE and 6000+ CPUs!
