AMD Athlon II X2 250 CPU Review
June 30, 2009 | 11:01
Tags: #250 #45nm #am3 #athlon #benchmarks #cpu #ddr3 #e5200 #ii #oc #ocing #overclocking #perform #performance #processor #review #x2
Companies: #amd #intel #test
File Compression Performance
WinRAR
Website: WinRAR
Our custom-made file compression test is split into two halves to cover a broad spectrum of performance. The first test compresses and encrypts a 176MB MPEG-2 file with the highest quality compression ratio.
The second test compresses and encrypts a folder of 400 photographs with the same compression settings.
Large File Compression & Encryption
WinRAR 3.71, Multithreaded, 276MB source file
  • Athlon II X2 250 (2x3.9GHz, 2.4GHz NB, 2.0GHz HTT)
  • Athlon X2 7850 BE (2x3.1GHz, 2.0GHz NB, 2.0GHz HTT)
  • Pentium Dual Core E5200 (2x4.0GHz, 1,333MHz FSB)
  • Athlon X2 7850 BE (2x2.7GHz, 1.8GHz NB, 2.0GHz HTT)
  • Athlon II X2 250 (2x3.0GHz, 2.0GHz NB, 2.0GHz HTT)
  • Athlon X2 6000+ (2x3.4GHz, 1.1GHz HTT)
  • Athlon X2 6000+ (2x3.1GHz, 1.0GHz HTT)
  • Pentium Dual Core E5200 (2x2.5GHz, 800MHz FSB)
  • 123
  • 139
  • 143
  • 146
  • 151
  • 158
  • 173
  • 182
100
150
200
Seconds (lower is better)
Small File Compression & Encryption
WinRAR 3.71, Multithreaded, 400 2048x1536 Photos
  • 112
  • 112
  • 131
  • 137
  • 137
  • 150
  • 158
  • 166
50
75
100
125
150
175
The Athlon II tops the table, and while it matches the E5200 when compressing small files, it has a clear lead in when compressing large files when both CPUs are overclocked. At stock speeds, the performance of the Athlon II is also very good - outperforming the other CPUs as well.
7-Zip
Download from: 7-Zip
Our community requested the inclusion of 7-Zip, a free alternative to WinRAR, and we've obliged accordingly. We use the internal benchmark, which measures compression and decompression performance in MIPS and provides an average result. It is multi-threaded so takes advantage of the latest multi-core and SMT enabled CPUs. We leave the benchmark to accumulate ten runs using a 32MB Dictionary size in order to get a solid, average result.
7-Zip
Internal Benchmark (32MB)
  • 7218
  • 6603
  • 5923
  • 5586
  • 5522
  • 5099
  • 4991
  • 4387
2000
3000
4000
5000
6000
7000
8000
MIPS (higher is better)
Once again the Athlon II tops the tables here by a large margin, with 7-Zip taking advantage of the larger memory bandwidth, faster access and high clock speed over the overclocked E5200. Even at its stock frequency the Athlon II outperforms the other CPUs as well.
null
