AMD Athlon II X4 620 CPU Review
October 26, 2009 | 09:33
Tags: #28ghz #45nm #620 #95w #athlon #benchmarks #cheap #core #cpu #four #ii #oc #overclock #perform #performance #processor #quad #review #x4
Companies: #amd #test
Lavalys Everest
Download from: www.lavalys.com
Everest is a comprehensive suite of benchmarking tools that can gauge the theoretical performance of every sub-system and component of your PC. We use the Memory and Cache benchmark to see how data flows into and out of the CPU.
Open the application and go to the Tools menu. Then click Cache and Memory Benchmark and click the Start Benchmark button. Everest will test the speed of all levels of CPU cache as well as memory throughput.
Everest Read Test
  • Athlon II X4 620 (4x3.5GHz, 2.45GHz NB, 2.2GHz HTT)
  • Phenom II X3 720 BE (3x3.5GHz, 2.4GHz NB, 2.0GHz HTT)
  • Phenom II X2 550 BE (2x3.8GHz, 2.6GHz NB, 2.0GHz HTT)
  • Athlon II X4 620 (4x2.6GHz, 2.0GHz NB, 2.0GHz HTT)
  • Core 2 Duo E7400 (2x4.2GHz, 1,600MHz FSB)
  • Phenom II X2 550 BE (2x3.1GHz, 2.0GHz NB, 2.0GHz HTT)
  • Phenom II X3 720 BE (3x2.8GHz, 2.0GHz NB, 2.0GHz HTT)
  • Core 2 Duo E7400 (2x2.8GHz, 1,066MHz FSB)
  • 9385
  • 8613
  • 8532
  • 8526
  • 8121
  • 8090
  • 8065
  • 6318
5000
7500
10000
MB/s (higher is better)
Everest Write Test
  • 8420
  • 8071
  • 7708
  • 7501
  • 6954
  • 6702
  • 6584
  • 5660
2000
3000
4000
5000
6000
7000
8000
9000
Everest Copy Test
  • 11395
  • 10857
  • 10682
  • 10116
  • 9817
  • 9774
  • 8392
  • 5910
5000
7500
10000
12500
Everest Latency Test
  • 46.1
  • 51.6
  • 52.5
  • 52.6
  • 54.9
  • 56.4
  • 61.4
  • 76.7
20
30
40
50
60
70
80
Nanoseconds - lower is better
The read performance is surprisingly good: the Athlon II X4 matches the Phenom II X2, overclocked to 3.8GHz at around 8,500MB/s. The write performance is similarly superior as even though it's CPU clock is slower and the CPU-NB clock is the same 2.0GHz, it still manages a few hundred MB/s more than the Phenom II X2 and X3. Copy performance doesn't see the same advantage but it's clear that AMD has optimised the memory controller slightly by a few nanoseconds.
When overclocked, the Athlon II X4 is clearly superior, outshining all the other CPUs by a significant margin despite not having the highest clock speed.
