Cinebench R10 64-bit
Download from: www.maxon.net
Cinebench R10 uses Maxon's Cinema 4D engine to render a photo-realistic scene of a shiny motorbike. The scene is highly complex, with reflections, ambient occlusion and procedural shaders so it gives a CPU a tough workout.
The test can be in run in single-threaded 1CPU mode or multi-threaded xCPU mode - just click the respective button. In this way, Cinebench R10 is useful for gauging the performance of each execution core of a CPU, as well as its overall performance.
As Cinema 4D is a real-world application - used on films such as Spider-Man, Star Wars among others - Cinebench R10 can be viewed as a real-world benchmark.
        Athlon II X4 620 (4x3.5GHz, 2.45GHz NB, 2.2GHz HTT)
        Phenom II X3 720 BE (3x3.5GHz, 2.4GHz NB, 2.0GHz HTT)
        Athlon II X4 620 (4x2.6GHz, 2.0GHz NB, 2.0GHz HTT)
        Core 2 Duo E7400 (2x4.2GHz, 1,600MHz FSB)
        Phenom II X3 720 BE (3x2.8GHz, 2.0GHz NB, 2.0GHz HTT)
        Phenom II X2 550 BE (2x3.8GHz, 2.6GHz NB, 2.0GHz HTT)
        Phenom II X2 550 BE (2x3.1GHz, 2.0GHz NB, 2.0GHz HTT)
        Core 2 Duo E7400 (2x2.8GHz, 1,066MHz FSB)
            13228
            10853
            10068
            8896
            8684
            8335
            6918
            6378
          5000
          7500
          10000
          12500
          15000
    Score - higher is better
        Phenom II X4 6MB L3 Cache (4x2.6GHz, 2.0Ghz NB)
        Athlon II X4 620 0MB L3 Cache (4x2.6GHz, 2.0GHz NB)
          5000
          7500
          10000
          12500
Naturally, the four cores work to the benefit of the Athlon II X4 here as it clearly makes a positive impression on the table for the same cost. The deficit to a full-fat Phenom II X4 is only about eight per cent too - not that much, despite the heavy multi-threading, although we suspect the amount of inter-cache snooping that benefits having a L3 cache is limited because each thread works on a completely independent part of the scene.
            5056
            4372
            4020
            3739
            3599
            3408
            3273
            2812
          2000
          3000
          4000
          5000
          1000
          1500
          2000
          2500
          3000
Single core performance is naturally a lot lower since the clock speed is more limited compared to the similarly priced competition. The difference between the Athlon and same clocked Phenom also remains in the same margin at seven per cent.
