SiSoftware Sandra Lite 2009.SP1 Beta (15.42)
Website: Sisoftware
AMD Athlon X2 7850 BE OC (2x3.1GHz, 1.8GHz HTT)
AMD Athlon X2 7850 BE (2x2.8GHz, 1.8GHz HTT)
AMD Athlon X2 7750 BE (2x2.7GHz, 1.8GHz HTT)
Intel Pentium Dual Core E5200 OC (2x4GHz, 1333MHz FSB)
AMD Athlon X2 5400+ (2x2.8GHz, 1.0GHz HTT)
AMD Athlon X2 6000+ (2x3.1GHz, 1.0GHz HTT)
Intel Pentium Dual Core E5200 (2x2.5GHz, 800MHz FSB)
10222
9947
9909
6596
6335
6330
4614
MB/s (higher is better)
Nanoseconds (lower is better)
SiSoft Sandra tells much the same story - the 7850 offers little more than the 7750 at stock speeds, and overclocked breaks the 10,000MB/s barrier in raw numbers - almost twice as much as an Intel clocked to 4GHz. SiSoft indicates the unganged twin 64-bit K10 architecture affords far more multi-threaded bandwidth compared to the older K8 one though, although the latencies are again creeping upwards with clock speed.
