AMD Athlon X2 7850 Black Edition CPU
April 28, 2009 | 07:03
Tags: #7850 #athlon #black #core #cpu #dual #edition #kuma #oc #overclock #overclocking #performance #processor #review #x2
Companies: #amd #test
AutoMKV x264 Encoding
Website: Doom9
We tested x264 compression using AutoMKV version 0.97.1 and x264 to to compress a 1.1GB DVD VOB file into 350MB MP4 file using a two-pass encode and we used a 112kbps LAME encoder to compress the audio. The whole process is dependent on both single and multi-core performance and the entire encoding time was recorded.
There's quite a shift to using MKV or MP4 wrappers for x264 content now, especially for movie content and those in the large anime fansubbing community. x264 doesn't have the same SSE enhancements as DivX 6.8, but the benefits of extra cache and better memory performance should still show notable improvements.
x.264 Encoding
AutoMKV 0.97.1, 1.05GB MPEG-2 VOB to 350MB x264 .mp4, LAME MT 112Kbps
  • Intel Pentium Dual Core E5200 OC (2x4GHz, 1333MHz FSB)
  • AMD Athlon X2 7850 BE OC (2x3.1GHz, 1.8GHz HTT)
  • AMD Athlon X2 7850 BE (2x2.8GHz, 1.8GHz HTT)
  • AMD Athlon X2 7750 BE (2x2.7GHz, 1.8GHz HTT)
  • AMD Athlon X2 6000+ (2x3.1GHz, 1.0GHz HTT)
  • Intel Pentium Dual Core E5200 (2x2.5GHz, 800MHz FSB)
  • AMD Athlon X2 5400+ (2x2.8GHz, 1.0GHz HTT)
  • 757
  • 986
  • 1067
  • 1107
  • 1142
  • 1220
  • 1314
500
750
1000
1250
1500
Time in Seconds (lower is better)
The 7850 Black Edition affords a slight but notable improvement over the previous 7750 BE, and both are very much faster than the stock clocked Intel E5200, however when we drop overclocking into the equation there's an eight percent improvement for the 3.1GHz clocked 7850 BE, but the Intel E5200 at 4GHz is still over 30 percent faster than this.
Handbrake H.264 Encoding
Website: HandBrake
Our test uses Handbrake - an open-source, GPL-licensed, multiplatform, multithreaded video transcoder, available for MacOS X, Linux and Windows - to encode a high resolution MPEG-2 video using the H.264 codec. This primarily tests multi-threaded CPU and memory subsystem performance.
Handbrake x.264 Video Encoding
Custom PC Benchmark
  • 552
  • 760
  • 837
  • 855
  • 861
  • 865
  • 936
500
750
1000
For Handbrake video encoding the AMD 7850 BE, 7750 BE and Intel E5200 are pretty evenly matched at stock speeds, and overclocked the 7850 Black Edition is around ten percent faster, but again the overclocked Intel E5200 nearly squeezes out a 38 percent faster time.
null
