AMD Phenom II X4 955 Black Edition CPU
April 23, 2009 | 10:02
Tags: #3 #955 #am3 #black #edition #guide #ii #oc #overclocking #overdrive #perform #performance #phenom #review #testing #x4
Companies: #amd #test
Power Consumption
When we test power consumption, we consider it as a whole platform so whether the CPU includes a memory controller or it's separate on the northbridge doesn't make a difference to what we measure at the wall and how much electricity is paid for. As always, we tested with all the power saving features enabled on the CPUs specifically.
While it's difficult to compare the motherboards in an apples to apples scenario, none of the motherboards used feature specific power regulation for the CPU phases and all of them are performance parts from DFI, Intel, MSI or Gigabyte.
Idle Power Consumption
Power at wall socket. BIOS Defaults, all onboard hardware enabled. Windows Desktop Idle
  • AMD Phenom II X4 940 (4x3.0GHz, 45nm C3, DDR2)
  • AMD Phenom II X4 920 (4x2.8GHz, 45nm C3, DDR2)
  • Core i7 920 (4x2.66GHz, 45nm, DDR3)
  • AMD Athlon X2 7750 (2x2.7GHz, 65nm B3, DDR2)
  • Core 2 Duo E8500 (2x3.16GHz, 45nm C0, DDR2)
  • Core 2 Quad Q9450 (4x2.66GHz, 45nm C1, DDR2)
  • Core 2 Quad Q9550 (4x2.83GHz, 45nm C1, DDR2)
  • AMD Phenom II X4 810 (4x2.6GHz, 45nm C2, DDR3)
  • AMD Phenom II X3 720 BE (3x2.8GHz, 45nm C2, DDR3)
  • AMD Phenom II X4 805 (4x2.5GHz, 45nm C2, DDR3)
  • AMD Phenom II X3 710 (3x2.6GHz, 45nm C2, DDR3)
  • Core 2 Quad Q9450 (4x2.66GHz, 45nm C1, DDR3)
  • Core 2 Duo E8500 (2x3.16GHz, 45nm C0, DDR3)
  • Core 2 Quad Q9550 (4x2.83GHz, 45nm C1 DDR3)
  • AMD Phenom X4 9950 BE (4x2.6GHz, 65nm B3, DDR2)
  • AMD Phenom II X4 955 BE (4x3.2GHz, 45nm C2, DDR3)
  • Core 2 Quad Q6700 (4x2.66GHz, 65nm G0, DDR2)
  • Core 2 Quad Q6700 (4x2.66GHz, 65nm G0, DDR3)
    • 98.0
    • 98.0
    • 103.0
    • 103.0
    • 107.0
    • 107.0
    • 108.0
    • 110.0
    • 110.0
    • 110.0
    • 110.0
    • 113.0
    • 113.0
    • 114.0
    • 115.0
    • 115.0
    • 130.0
    • 133.0
50
75
100
125
150
Watts (lower is better) - Average Reading
  • Idle
Load Power Consumption
Power at wall socket. BIOS Defaults, all onboard hardware enabled. Prime95 Load
  • Core 2 Quad Q9550 (4x2.83GHz, 45nm C1, DDR3)
  • AMD Phenom II X4 945 (4x3.0GHz, 45nm C3, DDR3)
  • AMD Phenom II X4 955 (4x3.2GHz, 45nm C3, DDR3)
  • AMD Phenom X4 9950 BE (4x2.6GHz, 65nm B3, DDR3)
    • 142.0
    • 147.0
    • 152.0
    • 165.0
    • 167.0
    • 173.0
    • 175.0
    • 177.0
    • 179.0
    • 179.0
    • 179.0
    • 186.0
    • 187.0
    • 196.0
    • 215.0
    • 215.0
    • 217.0
    • 240.0
    • 284.0
100
150
200
250
300
  • Load
Despite the fact the Phenom IIs clock down quite a long way to just 800MHz when idling, these power numbers are somewhat disappointing. The 940, with DDR2 and a DDR2 motherboard, are a good 17W lower power than the 945/955 CPUs and even 5W more power hungry than the other AM3 CPUs as well under idle conditions.
Under load and the Phenom II X4 945 and 955 consume more power than even the Core i7-920 with its extra DDR3 DIMM as it sits in the realm of the older 65nm Intel quad cores. Clock for clock, there's nearly a 30W difference between DDR3 setup over DDR2.
