Lavalys Everest 4.60.1540 Beta Memory Performance
Website: Lavalys
Core i7 920 (4x2.66GHz, 4.8GHz QPI, SMT enabled, DDR3)
AMD Phenom II X3 720 BE (3x2.8GHz, 2.0GHz HTT, DDR3)
AMD Phenom II X4 945 (4x3.0GHz, 2.0GHz HTT, DDR3)
AMD Phenom II X4 955 BE (4x3.2GHz, 2.0GHz HTT, DDR3)
Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB, DDR3)
AMD Phenom II X4 805 (4x2.5GHz, 2.0GHz HTT, DDR3)
AMD Phenom II X3 710 (3x2.6GHz, 2.0GHz HTT, DDR3)
AMD Phenom II X4 810 (4x2.6GHz, 2.0GHz HTT, DDR3)
Core 2 Quad Q9550 (4x2.83GHz, 1,333MHz FSB, DDR3)
Core 2 Quad Q9450 (4x2.66GHz, 1,333MHz FSB, DDR3)
AMD Phenom X4 9950 BE (4x2.6GHz, 2.0GHz HTT, DDR2)
AMD Phenom II X4 940 (4x3.0GHz, 1.8GHz HTT, DDR2)
AMD Phenom II X4 920 (4x2.8GHz, 1.8GHz HTT, DDR2)
AMD Athlon X2 7750 BE (2x2.7GHz, 1.8GHz HTT, DDR2)
Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB, DDR2)
Core 2 Quad Q6700 (4x2.66GHz, 1,066MHz FSB, DDR2)
Core 2 Quad Q9550 (4x2.83GHz, 1,333MHz FSB, DDR2)
Core 2 Quad Q9450 (4x2.66GHz, 1,333MHz FSB, DDR2)
Core 2 Quad Q6700 (4x2.66GHz, 1,066MHz FSB, DDR3)
5000
7500
10000
12500
MB/s (higher is better)
AMD Phenom II X4 805 (4x2.6GHz, 2.0GHz HTT, DDR3)
Core 2 Quad Q9650 (4x3.0GHz, 1,333MHz FSB, DDR3)
Core 2 Quad Q9650 (4x3.0GHz, 1,333MHz FSB, DDR2)
5000
7500
10000
12500
15000
Core i7 920 (4x2.66GHz, 6.4GHz QPI, SMT enable, DDR3)
AMD Phenom II X3 720 BE (3x2.8GHz, 2.0GHz HTT DDR3)
AMD Phenom II X4 810 (4x2.6GHz, 2.0GHz HTT DDR3)
AMD Phenom II X3 710 (3x2.6GHz, 2.0GHz HTT DDR3)
AMD Phenom II X4 805 (4x2.5GHz, 2.0GHz HTT DDR3)
20
30
40
50
60
70
80
Nanoseconds (lower is better)
Everest throws out some strange read results, although the memory write and copy performances are notably better thanks to the increase in clock speed (and DDR3 for a change). However, this can be offset or improved by increasing the northbridge frequency for Phenom II CPUs, which directly improves the read performance by three to four percent, write performance seven to ten percent, and copy performance of two to five percent per 200MHz increment.
