AMD Phenom II X4 955 Black Edition CPU
April 23, 2009 | 10:02
Tags: #3 #955 #am3 #black #edition #guide #ii #oc #overclocking #overdrive #perform #performance #phenom #review #testing #x4
Companies: #amd #test
File Compression & Encryption:
WinRAR
Website: WinRAR
Our file compression and decompression tests were split into two halves to cover a broad spectrum of performance. The first test we ran was to compress and encrypt the MPEG-2 source file from our video encoding test with the highest quality compression ratio. Secondly, we compressed and encrypted the folder of 400 photographs used in our Photoshop Elements test with the same compression settings.
Large File Compression & Encryption
WinRAR 3.71, Multithreaded, 276MB source file
  • Core i7 920 (4x2.66GHz, 4.8GHz QPI, SMT enabled, DDR3)
  • AMD Phenom II X4 955 BE (4x3.2GHz, 2.0GHz HTT, DDR3)
  • AMD Phenom II X4 945 (4x3.0GHz, 2.0GHz HTT, DDR3)
  • Core 2 Quad Q9550 (4x2.83GHz, 1,333MHz FSB, DDR3)
  • Core 2 Quad Q9450 (4x2.66GHz, 1,333MHz FSB, DDR3)
  • Core 2 Quad Q9550 (4x2.83GHz, 1,333MHz FSB, DDR2)
  • AMD Phenom II X4 920 (4x2.8GHz, 1.8GHz HTT, DDR2)
  • Core 2 Quad Q6700 (4x2.66GHz, 1,066MHz FSB, DDR3)
  • AMD Phenom II X4 940 (4x3.0GHz, 1.8GHz HTT, DDR2)
  • AMD Phenom II X3 720 BE (3x2.8GHz, 2.0GHz HTT, DDR3)
  • Core 2 Quad Q9450 (4x2.66GHz, 1,333MHz FSB, DDR2)
  • AMD Phenom II X3 710 (3x2.6GHz, 2.0GHz HTT, DDR3)
  • AMD Phenom X4 9950 BE (4x2.6GHz, 2.0GHz HTT, DDR2)
  • AMD Phenom II X4 810 (4x2.6GHz, 2.0GHz HTT, DDR3)
  • Core 2 Quad Q6700 (4x2.66GHz, 1,066MHz FSB, DDR2)
  • Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB, DDR3)
  • AMD Phenom II X4 805 (4x2.5GHz, 2.0GHz HTT, DDR3)
  • Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB, DDR2)
  • AMD Athlon X2 7750 BE (2x2.7GHz, 1.8GHz HTT, DDR2)
    • 78
    • 93
    • 105
    • 106
    • 109
    • 111
    • 113
    • 113
    • 113
    • 114
    • 115
    • 119
    • 121
    • 122
    • 123
    • 125
    • 125
    • 133
    • 165
50
75
100
125
150
175
Time in Seconds (lower is better)
  • Seconds
An impressive result from AMD again, as it performs 14 percent faster than the Q9550 here, but even despite the fact it's second in the table to the Core i7-920, it still lags behind by a large 19.2 percent. Compared to the DDR2 based Phenom II X4 920 and 940 CPUs though it's 21.5 percent faster, or a notable 20 seconds - a very nice improvement!
Small File Compression & Encryption
WinRAR 3.71, Multithreaded, 400 2048x1536 Photos
  • Core i7 920 (4x2.66GHz, 6.4GHz QPI, SMT enabled, DDR3)
  • AMD Phenom II X4 955 (4x3.2GHz, 2.0GHz HTT, DDR3)
    • 81
    • 91
    • 92
    • 94
    • 95
    • 99
    • 99
    • 100
    • 103
    • 104
    • 105
    • 109
    • 109
    • 113
    • 114
    • 117
    • 118
    • 122
    • 141
50
75
100
125
150
  • Seconds
The results are pretty much the same for many small files, except the Q9550 does a bit better here.
7-Zip
Website: 7-Zip
Our community requested the inclusion of 7-Zip, a free compression tool that is an alternative to WinRAR and we've obliged accordingly. Using the internal benchmark this measures compression and decompression performance in MIPS and provides an average result. It is multi-threaded so takes advantage of the latest multi-core and SMT enabled CPUs.
We left the benchmark to accumulate 10 runs using a 32MB Dictionary size in order to get a solid, average result.
7-Zip
Internal Benchmark
    • 15162.0
    • 11540.0
    • 10803.0
    • 10729.0
    • 10575.0
    • 10567.0
    • 10007.0
    • 9932.0
    • 9914.0
    • 9712.0
    • 9703.0
    • 9239.0
    • 8976.0
    • 8946.0
    • 6145.0
    • 6048.0
    • 5288.0
    • 4926.0
    • 4820.0
5000
7500
10000
12500
15000
MIPS (higher is better)
  • MIPS
Both the 955 and 945 Phenom II X4 CPUs perform very well again, pipping the Q9550 to the post and taking advantage of the DDR3 to edge ahead of the DDR2 940 CPU as well. The highly threaded Core i7-920 still dominates the table though with its massive lead, but the extra MHz do well for AMD.
