AMD Phenom II X6 1100T Black Edition Review
Written by Paul Goodhead
December 7, 2010 | 07:56
Tags: #6-core #920 #930 #athlon #best #cheapest #cpu #dual-core #fastest #mhz #overclocking #phenom #processorintel #quad-core #quickest #revision #x4 #x6
Companies: #amd
Media Benchmarks
Download from: bit-tech.net
We've developed our own suite of benchmarks using real-world and open-source applications to simulate how PCs are actually used. The suite comprises an image editing test using Gimp, a video encoding test using Handbrake and a multi-tasking test using 7-Zip to archive and encrypt a large batch of files while a HD movie plays in mplayer.
A score of 1,000 means that the test system is as fast as our reference PC, which used a 2.66GHz Intel Core 2 Duo E6750 at stock speed, 2GB of Corsair 1,066MHz DDR2 memory, a 250GB Samsung SpinPoint P120S hard disk and an Asus P5K Deluxe WiFi-AP motherboard. The scoring is linear, so a system scoring 1,200 points is 20 per cent faster than our reference system. Equally, a system scoring 1,200 is 4 per cent faster than a system scoring 1,150.
Multi-tasking with 7-Zip and mplayer
Websites: www.7-zip.org and www.mplayerhq.hu
Multi-tasking is a phrase with which we're all familiar, as most of us are now used to running multiple applications at the same time. However, to run multiple applications well you need a powerful (ideally multi-core) CPU and plenty of RAM.
Our multi-tasking test performs a massive file backup (with encryption) using 7-Zip, while simultaneously playing back a HD movie file using mplayer, making it a demanding test for any PC.
Multi-tasking Test
Media Benchmarks
  • Intel Core i7-930 (4.3GHz)
  • Intel Core i5-760 (4.1GHz)
  • Intel Core i5-750 (4.0GHz)
  • Intel Core i7-950 (4.3GHz)
  • Intel Core i7-950 (3.06GHz)
  • Intel Core i7-930 (2.8GHz)
  • Intel Core i5-750 (2.66GHz)
  • Phenom II X6 1100T BE (4.2GHz)
  • Phenom II X6 1090T BE (3.87GHz)
  • AMD Phenom II X4 970 (4.1GHz)
  • Intel Core i5-760 (2.8GHz)
  • AMD Phenom II X4 970 (3.5GHz)
  • Phenom II X6 1100T BE (3.3GHz)
  • Phenom II X6 1090T BE (3.2GHz)
  • Intel Pentium G6950 (4.62GHz)
  • AMD Athlon II X3 455 (3.85GHz)
  • AMD Athlon II X4 645 (3.7GHz)
  • AMD Athlon II X3 455 (3.1GHz)
  • AMD Athlon II X4 645 (3.1GHz)
  • Intel Pentium G6950 (2.8GHz)
  • 1785
  • 1683
  • 1644
  • 1614
  • 1503
  • 1498
  • 1249
  • 1241
  • 1241
  • 1235
  • 1227
  • 1104
  • 1038
  • 1023
  • 996
  • 899
  • 893
  • 808
  • 802
  • 692
1000
1500
2000
Score (points), higher is better
Overall Score
The overall score is an unweighted mean average of the scores of the three individual tests. A score of 1,000 means that the test system is as fast as our reference PC, which used a 2.66GHz Intel Core 2 Duo E6750 at stock speed, 2GB of Corsair 1,066MHz DDR2 memory, a 250GB Samsung SpinPoint P120S hard disk and an Asus P5K Deluxe WiFi-AP motherboard. The scoring is linear, so a system scoring 1,200 points is 20 per cent faster than our reference system. Equally, a system scoring 1,200 is 4 per cent faster than a system scoring 1,150.
Overall Media Benchmark Score
Media Benchmarks
  • 2328
  • 2195
  • 2082
  • 2038
  • 1762
  • 1727
  • 1674
  • 1638
  • 1604
  • 1544
  • 1490
  • 1483
  • 1442
  • 1367
  • 1339
  • 1290
  • 1247
  • 1102
  • 1028
  • 1027
1000
1500
2000
2500
Read our Perfomance Analysis
