Media Benchmarks
Download from: bit-tech.net
We've developed our own suite of benchmarks using real-world and open-source applications to simulate how PCs are actually used. The suite comprises an image editing test using Gimp, a video encoding test using Handbrake, and a multi-tasking test using 7-Zip to archive and encrypt a large batch of files while an HD movie plays in mplayer.
A score of 1,000 means that the test system is as fast as our reference PC, which used a 2.66GHz Intel Core 2 Duo E6750 at stock speed, 2GB of Corsair 1,066MHz DDR2 memory, a 250GB Samsung SpinPoint P120S hard disk and an Asus P5K Deluxe WiFi-AP motherboard. The scoring system is linear, so a machine scoring 1,200 points is 20 per cent faster than our reference system. Equally, a system scoring 1,200 is 4 per cent faster than a system scoring 1,150.
Multi-tasking with 7-Zip and mplayer
Websites: www.7-zip.org and www.mplayerhq.hu
Multi-tasking is a phrase with which we're all familiar, as most of us are now used to running multiple applications at the same time. However, to run multiple applications well you need a powerful (ideally multi-core) CPU and plenty of RAM.
Our multi-tasking test performs a massive file backup (with encryption) using 7-Zip, while simultaneously playing back an HD movie file using mplayer, making it a demanding test for any PC.
        Intel Core i5-2400 (3.1GHz)
        Intel Core i3-3220 (3.3GHz)
        AMD A10-6800K (4.73GHz)
        AMD A10-6700 (4.33GHz)
        Intel Core i3-2100 (3.1GHz)
        AMD A10-6800K (4.1GHz)
        AMD A10-6700 (3.7GHz)
        AMD A10-5800K (3.8GHz)
        AMD A10-5700 (3.4GHz)
        AMD A8-3870K (3.0GHz)
        AMD A8-3850 (2.9GHz)
            1494
            1410
            1227
            1219
            1141
            1122
            1089
            1071
            1039
            768
            757
          500
          750
          1000
          1250
          1500
    Points (higher is better)
Overall Score
The overall score is an unweighted mean average of the scores of the three individual tests. A score of 1,000 means that the test system is as fast as our reference PC, which used a 2.66GHz Intel Core 2 Duo E6750 at stock speed, 2GB of Corsair 1,066MHz DDR2 memory, a 250GB Samsung SpinPoint P120S hard disk and an Asus P5K Deluxe WiFi-AP motherboard. The scoring system is linear, so a machine scoring 1,200 points is 20 per cent faster than our reference system. Equally, a system scoring 1,200 is 4 per cent faster than a system scoring 1,150.
            1850
            1694
            1585
            1499
            1476
            1447
            1395
            1366
            1272
            1082
            1059
Read our
performance analysis.
