Paint.NET x64 3.05
Website: Paint.NET
This is the 64-bit version of the popular free image editing software, Paint.NET. It's not as advanced as something like Adobe Photoshop CS3 or Corel Paint Shop Pro Photo X2, but it does serve well for most image editing tasks.
We used the PDNBench script to test the processing times for a range of images and filters. The multi-threaded software also takes advantage of multi-core processors quite effectively.
For more information on what the benchmark script entails, please see
this thread on the Paint.NET forums.
Core 2 Extreme QX9650 (4x3.00GHz, 1333MHz FSB)
Core 2 Extreme QX6850 (4x3.00GHz, 1333MHz FSB)
Core 2 Quad Q6700 (4x2.67GHz, 1066MHz FSB)
Core 2 Quad Q6600 (4x2.40GHz, 1066MHz FSB)
Phenom 9900 (4x2.6GHz, 2.0GHz HTT)
Phenom 9700 (4x2.4GHz, 2.0GHz HTT)
Core 2 Duo E6850 (2x3.00GHz, 1333MHz FSB)
Phenom 9600 ES (4x2.3GHz, 2.0GHz HTT)
Phenom 9600 Black Edn (4x2.3GHz, 2.0GHz HTT)
Core 2 Duo E6750 (2x2.67GHz, 1333MHz FSB)
Athlon 64 X2 6400+ (2x3.20GHz, 1.0GHz HTT)
Athlon 64 X2 6000+ (2x3.00GHz, 1.0GHz HTT)
14.472
15.648
17.614
19.346
26.206
27.950
28.993
29.036
29.226
33.056
43.054
46.277
Time in Seconds (lower is better)
Again the Black Edition performs within a fraction of the ES 9600 we previously tested.
File Compression & Encryption:
Our file compression and decompression tests were split into two halves to cover a broad spectrum of performance. The first test we ran was to compress and encrypt the MPEG-2 source file from our video encoding test with the highest quality compression ratio. Secondly, we compressed and encrypted the folder of 400 photographs used in our Photoshop Elements test with the same compression settings.
97
103
111
115
122
125
127
128
132
134
150
159
50
75
100
125
150
175
92
98
111
111
123
127
131
140
141
141
155
156
50
75
100
125
150
175
The Black Edition actually shaves off a couple of seconds in large file testing, but performs identically in small file compression.
