Athlon X2 7750 vs. Intel E5200 OC & Value
December 22, 2008 | 08:26
Tags: #athlon #benchmark #cpu #kuma #overclock #overclocking #processor #review #testing #value #x2
Companies: #amd #test
Lavalys Everest 4.60.1540 Beta Memory Performance
Website: Lavalys
Everest Memory Performance Test
Everest 4.60 beta
  • AMD Athlon X2 6000+ (2x3.1GHz, 1.0GHz HTT)
  • AMD Athlon X2 5200+ (2x2.7GHz, 1.0GHz HTT)
  • AMD Athlon X2 7750 OC (2x3.1GHz, 1.8GHz HTT)
  • AMD Athlon X2 7750 BE (2x2.7GHz, 1.8GHz HTT)
  • AMD Athlon X2 7550 (2x2.5GHz, 1.8GHz HTT)
  • AMD Athlon X2 4850e (2x2.5GHz, 1.0GHz HTT)
  • AMD Phenom X3 8450 (3x2.1GHz, 1.8GHz HTT)
  • Intel Pentium Dual Core E5200 OC (2x4GHz, 1333MHz FSB)
  • Intel Pentium Dual Core E5200 (2x2.5GHz, 800MHz FSB)
    • 8776.0
    • 8747.0
    • 8439.0
    • 8466.0
    • 7623.0
    • 8275.0
    • 7852.0
    • 4606.0
    • 8085.0
    • 7765.0
    • 4610.0
    • 7964.0
    • 7620.0
    • 4570.0
    • 7838.0
    • 7571.0
    • 7050.0
    • 7341.0
    • 7455.0
    • 4471.0
    • 7533.0
    • 6588.0
    • 7012.0
    • 0.0
    • 5341.0
    • 4243.0
    • 0.0
2000
3000
4000
5000
6000
7000
8000
9000
Nanoseconds (lower is better)
  • Read (MB/s)
  • Write (MB/s)
  • Copy (MB/s)
Everest Memory Latency Test
Everest 4.60 beta
  • 47.2
  • 48.1
  • 53.3
  • 55.5
  • 56.1
  • 57.9
  • 58.5
  • 78.9
  • 96.9
50
75
100
There's no real memory performance improvement when simply overclocking using the multiplier on the 7750 Black Edition - here's a bit more read and copy performance but without being able to increase the northbridge clock the write performance remains the same. The overclocked Intel E5200 performance increases greatly as we jacked up the FSB from 800 to 1,333MHz - the write performance in particular makes better use of the same DDR2-800MHz at 4-4-4-12-2T.
Intel's latency also drops by nearly 23 percent, but the new Athlon doesn't see much of a latency improvement at all.
