Athlon X2 7750 vs. Intel E5200 OC & Value
December 22, 2008 | 08:26
Tags: #athlon #benchmark #cpu #kuma #overclock #overclocking #processor #review #testing #value #x2
Companies: #amd #test
SiSoftware Sandra Lite 2009.SP1 Beta (15.42)
Website: Sisoftware
Sisoft Sandra Unbuffered Memory Test
Sisoft Sandra 15.42
  • AMD Phenom X3 8450 (3x2.1GHz, 1.8GHz HTT)
  • AMD Athlon X2 7750 OC (2x3.1GHz, 1.8GHz HTT)
  • AMD Athlon X2 7750 BE (2x2.7GHz, 1.8GHz HTT)
  • AMD Athlon X2 7550 (2x2.5GHz, 1.8GHz HTT)
  • AMD Athlon X2 6000+ (2x3.1GHz, 1.0GHz HTT)
  • AMD Athlon X2 5200+ (2x2.7GHz, 1.0GHz HTT)
  • Intel Pentium Dual Core E5200 OC (2x4GHz, 1333MHz FSB)
  • AMD Athlon X2 4850e (2x2.5GHz, 1.0GHz HTT)
  • Intel Pentium Dual Core E5200 (2x2.5GHz, 800MHz FSB)
  • 9096
  • 9022
  • 8895
  • 8798
  • 6993
  • 6912
  • 6596
  • 6227
  • 4614
5000
7500
10000
MB/s (higher is better)
Sisoft Sandra Random Memory Latency Test
Sisoft Sandra 15.42
  • 82
  • 83
  • 83
  • 87
  • 93
  • 94
  • 95
  • 95
  • 111
50
75
100
125
Nanoseconds (lower is better)
The clock speed improvement for the Athlon X2 7750 means it nearly catches up with the Phenom X3 8450 here - the extra core of the Phenom generally performs better in the multithreaded memory performance test of Sisoft Sandra. Again, there's not a huge improvement in memory bandwidth from the extra 400MHz between the stock and overclocked Athlon X2 7750s, whereas the Intel E5200 overclocking provides far more bandwidth - nearly 43 percent.
And again, like Everest, there's little benefit seen when overclocking the Athlon, whereas the Intel improves quite a lot.
