2D Performance
To give us an idea of general system performance, we benchmarked our £400 gaming PC both before and after overclocking across a range of fairly typical application benchmarks.
As you'll see below, there are some decent performance gains to be had as a result of increasing our processor, memory and GPU clock speeds. All of these benchmarks focus on the processor, memory and general system performance - none of these applications are GPU-accelerated today, but that's not to say they won't be in the future.
That said, we believe that it's important to build a balanced PC - one that's able to deliver good performance in both CPU and GPU accelerated applications. This is something we've been talking about for years now and when you've got a tight budget like the one we're working to today, it's especially important that you choose the right mix of components.
E2160 @ 1800MHz / DDR2-667 5-5-5-15-2T / 9600 GT @ 700/1750/2000MHz
E2160 @ 2907MHz / DDR2-800 5-5-5-15-2T / 9600 GT @ 774/1896/2084MHz
2000
3000
4000
5000
6000
7000
8000
MB/sec
20
30
40
50
60
70
80
90
nanoseconds (lower is better)
Time in Seconds (lower is better)
The average performance increase we saw as a result of the overclock was around 50 percent, which isn't too shabby when you consider just how much this machine costs as a baseline.
