Intel Core i7-975 Extreme Edition Review
Written by Clive Webster
June 22, 2009 | 09:17
Tags: #920 #965 #975 #benchmark #comparison #core-i7 #crazy-but-cool #extreme-edition #lga1366 #overclocking #performance
Companies: #ee #intel #test
File Compression Performance
WinRAR
Website: WinRAR
Our custom-made file compression test is split into two halves to cover a broad spectrum of performance. The first test compresses and encrypts a 176MB MPEG-2 file with the highest quality compression ratio.
The second test compresses and encrypts a folder of 400 photographs with the same compression settings.
Small File Compression & Encryption
WinRAR 3.71, Multithreaded, 400 2048x1536 Photos
  • Intel Core i7-975 Extreme Edition
  • Intel Core i7-965 Extreme Edition
  • Intel Core i7-920
  • AMD Phenom II X4 955 Black Edition
    • 67
    • 56
    • 68
    • 57
    • 81
    • 56
    • 96
    • 79
50
75
100
Time in Seconds (lower is better)
  • Stock Speed
  • Overclocked
Large File Compression & Encryption
WinRAR 3.71, Multithreaded, 276MB source file
  • Intel Core i7-920
    • 66
    • 57
    • 68
    • 57
    • 77
    • 55
    • 103
    • 92
50
75
100
  • Stock Speed
  • Overclocked
The WinRAR tests show nothing we haven't already seen in the other tests - the 975 EE is slightly faster than the 965 EE, though all Core i7 CPUs were roughly as fast as each other as they all overclocked to roughly the same level due to cooling constraints. The AMD 955 BE is off the pace though, taking 96 seconds to compress the small files and 103 seconds to compress the large; the 920 did the same tasks in 81 seconds and 77 seconds respectively.
7-Zip
Download from: 7-Zip
Our community requested the inclusion of 7-Zip, a free alternative to WinRAR, and we've obliged accordingly. We use the internal benchmark, which measures compression and decompression performance in MIPS and provides an average result. It is multi-threaded so takes advantage of the latest multi-core and SMT enabled CPUs. We leave the benchmark to accumulate ten runs using a 32MB Dictionary size in order to get a solid, average result.
File Compression & Encryption (7-Zip)
7-Zip 4.65 (x64), built-in benchmark
  • Intel Core i7-920
    • 19033
    • 24088
    • 18738
    • 23573
    • 15634
    • 23034
    • 11414
    • 13537
10000
15000
20000
25000
MB/s (higher is better)
  • Stock Speed
  • Overclocked
7-Zip shows much the same results as WinRAR, which ranks on the list of surprises somewhere between the Sun rising and MPs not wanting to disclose the full extent of their expense-account abuses. The 975 EE is slightly faster than the 965 EE, while the AMD 955 BE is off the pace of the Core i7s.
