IMC Performance
Lavalys Everest 4.60.1540 Beta Memory Performance
Website: Lavalys
CPU Uncore Clock: 2133MHz
CPU Uncore Clock: 2667MHz
CPU Uncore Clock: 2933MHz
CPU Uncore Clock: 3200MHz
5000
7500
10000
12500
15000
MB/s (higher is better)
5000
7500
10000
12500
15000
Nanoseconds (lower is better)
The read performance hit a little bit of a bump at 2.67GHz to 2.93GHz, but improves again at 3.2GHz - Everest was consistent in reporting this and we can allude it's possibly due to core-uncore ratio changes, perhaps: 1:1.23 works better than 1:1.1. Overall though there are significant increases all round, although even though memory controller frequency elevation does give it a lower latency, as we saw previously, optimising the memory timings works out better in that equation.
L3 Cache Performance
24778.0
24932.0
25343.0
24912.0
10000
15000
20000
25000
15313.0
18032.0
19028.0
20236.0
23667.0
24958.0
25428.0
25753.0
10000
15000
20000
25000
Just to confirm our theory above - the latency of a 2.93GHz CPU Uncore gave us a consistently 0.3ns higher latency than 2.67GHz, indicating the other three are slightly more optimised for Core-Uncore data transfer. Increasing the Uncore frequency helps L3 cache writes hugely - by over 32 percent - but it does little for copy performance and even less for read.
