Memory Timings
SiSoftware Sandra Lite 2009.SP1 Beta (15.42)
Website: Sisoftware
      1600MHz 8-8-8-21-1T
      1600MHz 9-9-9-24-1T
      1600MHz 8-8-8-21-2T
      1333MHz 6-6-6-15-1T
      1333MHz 7-7-7-18-1T
      1333MHz 8-8-8-21-1T
      1333MHz 9-9-9-24-1T
      1600MHz 8-7-8-18-1T
      1708MHz OC 9-9-9-24-2T
      1066MHz 5-5-5-15-1T
      1066MHz 6-6-6-15-1T
      1066MHz 7-7-7-18-1T
      1066MHz 8-8-8-21-1T
      1066MHz 9-9-9-24-1T
          28676.5
          28016.5
          27668.0
          24819.5
          24583.5
          24140.5
          23603.0
          19862.0
          19605.0
          16419.0
          16214.0
          16075.0
          15936.0
          15670.0
        10000
        15000
        20000
        25000
        30000
  MB/s (higher is better)
      1600MHz 8-8-8-21-1T
      1600MHz 8-7-8-18-1T
      1600MHz 8-8-8-21-2T
      1333MHz 6-6-6-15-1T
      1600MHz 9-9-9-24-1T
      1066MHz 5-5-5-15-1T
      1333MHz 7-7-7-18-1T
      1066MHz 6-6-6-15-1T
      1333MHz 8-8-8-21-1T
      1333MHz 9-9-9-24-1T
      1066MHz 7-7-7-18-1T
      1066MHz 8-8-8-21-1T
      1066MHz 9-9-9-24-1T
          59
          60
          61
          62
          62
          64
          67
          67
          71
          71
          71
          75
          79
        20
        30
        40
        50
        60
        70
        80
  Nanoseconds (lower is better)
Sisoft Sandra tells much the same story, although it doesn't like it at all when we pushed the memory further than its rated values in terms of both latency
and frequency, yielding a very poor result. There are huge jumps for frequency elevation rather than very small ones for latency optimisations - the gap is far larger than in Everest.
IMC Performance
      CPU Uncore Clock: 2133MHz
      CPU Uncore Clock: 2667MHz
      CPU Uncore Clock: 2933MHz
      CPU Uncore Clock: 3200MHz
        20
        30
        40
        50
        60
        70
        80
Increasing the memory controller clock alone does little for the raw memory performance, but it does reduce the latency slightly.
