Intel Core i7 Memory Performance
January 26, 2009 | 10:11
Tags: #benchmarks #channel #compare #comparison #controller #core #ddr3 #dual #i7 #integrated #performance #single #testing #triple #x58
Companies: #corsair #intel
Multitasking Performance
Website: MPC-HC
Website: 7Zip
To run multiple applications well you need a powerful (ideally multi-core) CPU and plenty of RAM. Our multitasking test performs a massive file backup (with encryption) using 7Zip, while simultaneously playing back a HD movie file using Media Player Classic, making it a seriously demanding test for any PC.
Timings: Multitasking Test
CustomPC Benchmark
  • 1708MHz 9-9-9-24-2T
  • 1600MHz 8-8-8-21-1T
  • 1600MHz 8-8-8-21-2T
  • 1600MHz 9-9-9-24-1T
  • 1333MHz 6-6-6-15-1T
  • 1066MHz 5-5-5-15-1T
  • 1333MHz 7-7-7-18-1T
  • 1066MHz 6-6-6-15-1T
  • 1333MHz 8-8-8-21-1T
  • 1333MHz 9-9-9-24-1T
  • 1066MHz 7-7-7-18-1T
  • 1066MHz 8-8-8-21-1T
  • 1066MHz 9-9-9-24-1T
  • 118
  • 119
  • 120
  • 120
  • 122
  • 124
  • 128
  • 131
  • 132
  • 133
  • 134
  • 140
  • 145
50
75
100
125
150
Seconds
IMC: Multitasking Test
  • CPU Uncore Clock: 2133MHz
  • CPU Uncore Clock: 2667MHz
  • CPU Uncore Clock: 2933MHz
  • CPU Uncore Clock: 3200MHz
  • 147
  • 141
  • 136
  • 136
50
75
100
125
150
Seconds
We see a nice performance elevation for the CPU memory core frequency, although it does seem to tail off between 2.93-3.2GHz, unlike the several second improvements seen above it.
The memory performance elevation is a notable 25 seconds, and it scales linearly with frequency and timing optimisations which is nice to see. In a Core i7 system with its eight threads, this is an important result because it's designed for heavy multi-threading and multi-tasking - while up to this point our benchmarks have been run singley (even if they are multi-threaded), doing multiple things at once is more in line with the work people do.
1T versus 2T does little to benefit here, but 1,333MHz C8 to C6 for example can shave a solid ten seconds, or eight percent off the result. Likewise, going from a low latency 1,333MHz C7 to 1,600MHz C9 also sees a seven percent increase in performance.
