Intel Core i7 - Nehalem Architecture Dive
November 3, 2008 | 05:57
Tags: #45nm #analysis #architecture #core #cpu #detail #discussion #i7 #inside #lga1366 #mode #nehalem #qpi #quad #smt #turbo
Companies: #intel
Show me the cache
The first Core i7 CPUs to launch are native quad cores - there will be no dual cores until the budget Havendale CPUs arrive and eight core variants are currently limited to the multi-socket server level Nehalem-EX, aka Beckton. The Core i7 processor drops the large, shared L2 cache in favour of much smaller (256KB), but 4ns faster, dedicated L2 cache instead that is also buffered by a large 8MB L3 cache.
It's important to note that the L3 cache exists in the "Uncore" section, which works at a lower frequency to the cores - this is identical to how AMD handles its L3 cache, including linking the L3 cache to its memory controller frequency, although unlike HyperTransport, the QPI is not frequency linked.
Since all the caches are inclusive, instead of exclusive, it means that 1.26MB of the 8MB is lost to mirroring what is in the other caches, however this also means it acts as a snoop filter. For example, if a core has a local L1 and L2 cache miss, it can check L3 cache without interfering with the other cores, freeing their resources and saving time.
Each level of cache takes considerably longer to access than the last, and while Core i7 now has 35ns 8MB shared across four cores, rather than 15ns 6MB shared across just two, means not only less, but slower on-die cache per core. The offset to this is that the memory access latency is ~40 percent less than of the Core 2's because the L3 cache is closely linked to the memory controller. While this is important, an efficient, low latency link between the memory/L3 cache and the Execution cores is essential for the best performance.
Cache Latency
  • Core i7
  • Core 2 (45nm)
  • Core 2 (65nm)
  • Phenom X4
    • 4
    • 11
    • 36
    • 3
    • 15
    • 0
    • 3
    • 14
    • 0
    • 3
    • 15
    • 49
20
30
40
50
Nanoseconds (lower is better)
  • L1
  • L2
  • L3
Hyper Thread a multi-multi-core
Simultaneous Multi-Threading (or SMT), branded as "Intel Hyper Threading Technology" (or HTT), makes a return as well. This technique allows use of multiple resources on a single core, for more than one executing thread. This can effectively a quad core be read as an octo-core within the OS, as it allows a maximum of two threads per core.
HTT was first introduced back in the days of Netburst and the Northwood core, offering the use of greater IPC (instructions per clock cycle) given the long pipelines of Netburst. It was left out of Core microarchitecture as it was deemed "unnecessary" by Intel because of the very efficient pipeline. Sadly this lead to many associating a long pipeline with SMT to hide resource access latency, and when Intel announced it would reintroduce the technology with Core i7, some questioned if the pipeline had become long and inefficient once again.
However after testing HTT on Core i7 it seems Intel has chiselled out quite a lean machine that means Nehalem still uses an efficient pipeline built off the foundation of Core 2, but its "wider" design with more efficient memory access and inter-core discussion (L3 cache) should mean it delivers more efficient multi-thread handling whether it's Thread or Instruction Level Parallelism.
Whereas previously very few programs were multi-threaded during the Pentium 4 era - this saw generally little performance increase for using SMT, depending on how the program was written and how easily it was to shoehorn some Instruction Level Parallelism (ILP) out of it. In some cases, this ended up cache-thrashing as resources were competed for and it could also be partly why Core 2 dropped SMT. Core 2's efficient pipeline and improved memory predictors would have been butchered in some cases if the memory bandwidth was further competed for, and especially in a quad core if the data had to navigate between the two dies because it would put far more pressure on the inherently limited Front Side Bus model.
As Intel pushes multi-threading much harder to software developers as a means of performance improvements, it's clear that extremely threaded or resource uncompetitive software will benefit the most from SMT.
Posted by Langer - Mon Nov 03 2008 06:32
Sounds very promising.
Posted by RotoSequence - Mon Nov 03 2008 06:44
Looks interesting, but there's a strong overtone of reservation in the article. Were you perchance thinking "why is everything but the execution core changed?"
Posted by Adnoctum - Mon Nov 03 2008 07:13
I'm unsure of BitTech's feeling on links to competing sites, so I don't know if I'm committing a massive faux pas or what.
TechReport previewed two X58 mobos (Intel DX58SO, Asus P6T Deluxe) hitched up to a Core i7-965 Extreme. It includes some benchmarks.
They can't give an i7 preview yet, but you can compare specific application performance figures with a big CPU comparison review they did in April on the Q9300.
I'm not too impressed by the i7 just yet, and this architecture briefing explains why. Hugely more expensive (both CPU and entire platform), with mixed performance results.
BTW, P6T Cheesecake. Cheaper and faster.
Posted by xtremeownage - Mon Nov 03 2008 07:17
Any new processor that requires a new socket is an expensive upgrade. Intel can forget getting my money for a while because the q6600 hasn't even been pushed to its limits let alone have all the 4 cores running at 100% load at any given time. Hardly any game as come to this point. Alan Wake may in fact pull this 1 off but even then the xbox 360 has 3 cores so why bother upgrading from q6600 to i7 when the 360 price has fallen dramatically for us gamers.
From a a developers point of view whether it be 3d animation and other intensive tasks then maybe they can consider these new processors. I would like to also stress the introduction of Physic cores in graphics card play a better role in processing physics calculations. Adobe and other companies use Nvidia GPU Cores to run software intensive tasks these days and the performance gains are phenomenal. I really don't see the point of upgrading if you already own the latest GPU's from Nvidia and ATi riding shot gun along side a Q6600.
null
