Multi-tasking Performance
Website: MPC-HC
Website: 7-Zip
Multi-tasking is a phrase with which we're all familiar, because most of us are now used to running multiple applications at the same time. However, to run multiple applications well you need a powerful (ideally multi-core) CPU and plenty of RAM.
Our multi-tasking test performs a massive file backup (with encryption) using 7-Zip, while simultaneously playing back an HD movie file using mplayer, making it a demanding test for any PC.
Intel Core i7-3770K (3.5GHz/4.8GHz)
Intel Core i7-2600K (3.4GHz/5GHz)
Intel Core i5-3570K (3.4GHz/5GHz)
Intel Core i7-4770K (3.5GHz/4.7GHz)
Intel Core i7-3960X Extreme Edition (3.3GHz/4.7GHz)
Intel Core i5-2500K (3.3GHz/5GHz)
Intel Core i5-4670K (3.4GHz/4.6GHz)
Intel Core i7-3930K (3.2GHz/4.7GHz)
Intel Core i7-990X Extreme Edition (3.46GHz/4.6GHz)
Intel Core i5-2400 (3.1GHz)
AMD FX-8150 (3.6GHz/4.818GHz)
AMD FX-8350 (4GHz/4.8GHz)
Intel Core i7-920 (2.66GHz/4.04GHz)
Intel Core i3-2100 (3.1GHz)
AMD A10-6800K (4.1GHz/4.7GHz)
AMD Phenom II X6 1100T Black Edition (3.3GHz/4.2GHz)
AMD FX-8120 (3.1GHz/4.65GHz)
Intel NUC D54250WYK (Core i5-4250U)
Intel NUC DC53427RKE (Core i5-3427U)
Intel NUC D33217CK (Core i3-3217U)
Score, higher is better
Read our
performance analysis.
Overall Score
The overall score is an unweighted mean average of the scores of the three individual tests.
1000
1500
2000
2500
3000
Read our
