PCMark Vantage x64
Publisher: Futuremark
PCMark Vantage x64 is a Vista-only 64-bit productivity benchmark that tests a range of standard application types providing a general performance number in respect to other systems. It tests multi-core processors and requires a processor with at least SSE2 support and a graphics card that supports Shader Model 2.0 or higher.
There are test scenarios for High Definition TV and Movies, Gaming, Memory, Music, Communications, Internet, General Productivity and Hard Drive. They cover the broad range of typical software a PC user will use and acts as a good "one stop" benchmark for general system performance.
We've included two graphs of results - one which includes just the overall score, and the other is the component scores, minus hard drive performance which was very consistent across the board.
Core 2 Extreme QX9650 (4x3.00GHz, 1333MHz FSB)
Core 2 Extreme QX6850 (4x3.00GHz, 1333MHz FSB)
Core 2 Quad Q6700 (4x2.67GHz, 1066MHz FSB)
Core 2 Quad Q6600 (4x2.40GHz, 1066MHz FSB)
Core 2 Duo E6850 (2x3.00GHz, 1333MHz FSB)
Core 2 Duo E6750 (2x2.67GHz, 1333MHz FSB)
Athlon 64 X2 6400+ (2x3.20GHz, 2.0GHz HTT)
Athlon 64 X2 6000+ (2x3.00GHz, 2.0GHz HTT)
5069
4970
4207
4128
4008
3852
3577
3483
2000
3000
4000
5000
PCMarks
Memories
TV and Movies
Gaming
Music
Communications
Productivity
4401
4353
4057
3859
3821
3651
3360
3235
4002
3859
3652
3473
3010
2614
2678
2513
5732
5458
5120
4956
4933
4607
4626
4509
4198
4060
3669
3500
3729
3494
3255
3133
4974
4938
4153
4150
4102
2847
3098
2948
4972
4966
4446
4289
4694
4428
4222
4063
2000
3000
4000
5000
6000
PCMarks
Core 2 Quad Q6700
Core 2 Quad Q6600
Core 2 Duo E6850
Core 2 Duo E6750
Athlon 64 X2 6400+
Athlon 64 X2 6000+
Overall both the QX6850 and QX9650 stand out from the crowd here with the QX9650 around 100 PCMarks faster than the QX6850. Quad-core processors outperform higher clocked dual-core chips in this benchmark, even despite the extra memory bandwidth of the E6x50 processors. The QX9650 particularly pushes ahead in "Gaming" (it's really just scenes from 3DMark 06), TV and Movies and Music, with less elsewhere, however it does still remain on top in all tests.
