Overclocking AMD's Phenom II X3 720 BE
May 11, 2009 | 11:03
Tags: #720 #be #bios #black #budget #core #edition #enthusiast #guide #ii #motherboard #overclocking #performance #phenom #triple #x3
Companies: #amd #asus #msi
GIMP Image Editing
Website: GUN Image Manipulation Program (GIMP)
Our GIMP image editing test simulates how well a PC can manipulate a collection of large digital photos, and to achieve a low time requires a PC with a powerful CPU, plenty of quick memory and efficient hard disk drive access.
Overclocking AMD's Phenom II X3 720 BE Image Editing, Video Encoding and Multitasking
GIMP Image Editing Test
CustomPC Benchmark
  • Intel Core 2 Duo E7500 (2x4.xxGHz)
  • Intel Core 2 Quad Q6600 (4x3.5GHz)
  • AMD Phenom II X3 720 Black Edition (3x3.7GHz)
  • AMD Phenom II X3 720 Black Edition (3x2.8GHz)
  • 242
  • 290
  • 309
  • 400
200
300
400
Seconds (lower is better)
In our image editing test, the 720 Black Edition is the slowest of all. It's 19 seconds behind the Q6600, and much slower than the E7500. As such, the green dot in the graph above is above the line (where a lower time is better), indicating the AMD is, of course, worse value in this test.
Handbrake H.264 Encoding
Website: HandBrake
Our test uses Handbrake - an open-source, GPL-licensed, multiplatform, multithreaded video transcoder, available for MacOS X, Linux and Windows - to encode a high resolution MPEG-2 video using the H.264 codec. This primarily tests multi-threaded CPU and memory subsystem performance.
Handbrake h.264 Video Encoding
CustomPC Benchmark
  • 437
  • 491
  • 511
  • 615
200
300
400
500
600
Stretching out a strong second place by 20 seconds over the dual core E7500, the 720 Black Edition is a minute behind the Core 2 Quad Q6600. If you want to encode video, the answer is to still grab a quad core. As such, the Q6600 (red dot) is considerably better value, leaving the Phenom II X3 720 behind.
Mulitasking Performance
Website: MPC-HC
Website: 7Zip
To run multiple applications well you need a powerful (ideally multi-core) CPU and plenty of RAM. Our multitasking test performs a massive file backup (with encryption) using 7Zip, while simultaneously playing back a HD movie file using Media Player Classic, making it a seriously demanding test for any PC.
Multitasking Test
CustomPC Benchmark
  • 173
  • 195
  • 200
  • 211
100
150
200
In multitasking the 720 Black Edition rules the roost: the large memory bandwidth from the independent memory memory channels, and better combination of higher clock speed than the Q6600 quad core, but also an extra core compared to the E7500. As such, the green AMD blob in the graph above is lower than the others meaning it offers better value - like we'd expect.
