X3:Terran Conflict
Publisher: EgoSoft
X3: Terran Conflict is the latest space-based trading and fighting game in the X3 series. It uses masses of polygons and geometry to create the complex ships and so is a very stressful test for a CPU.
Remember that it's the CPU that constructs the wire-frame models of game objects, before a GPU can apply texture and lighting.
To run the benchmark, first download the
rolling demo and set the graphics options as below. Then remember to tick the 'Run as benchmark' box and hit go. We average the results of the four component tests to give a single minimum and average frame rate.
      Intel Core i5-750 (4.15GHz)
      Intel Core i5-661 (4GHz)
      Intel Core i3-530 (4.07GHz)
      AMD Phenom II X4 965 Black Edition (3.99GHz)
      Intel Core i5-661 (3.33GHz)
      Intel Core 2 Quad Q6600 (3.7GHz)
      Intel Core i5-750 (2.66GHz)
      AMD Phenom II X4 965 Black Edition (3.4GHz)
      AMD Athlon II X4 630 (3.71GHz)
      Intel Core i3-530 (2.93GHz)
      Intel Core 2 Duo E8400 (4.25GHz)
      AMD Athlon II X4 630 (2.8GHz)
      Intel Core 2 Duo E8400 (3GHz)
      Intel Core 2 Quad Q6600 (2.4GHz)
  Frame rate (fps), higher is better. Blue: stock sp
For performance conclusions, see
page 10
