Overclocking Intel's Core i7 920
November 6, 2008 | 08:57
Tags: #920 #benchmark #bios #by #core #easy #eclipse #guide #i7 #i7-920 #overclocking #p6t #performance #result #step
Companies: #asus #intel #msi #test
File Compression & Encryption:
WinRAR
Website: WinRAR
Our file compression and decompression tests were split into two halves to cover a broad spectrum of performance. The first test we ran was to compress and encrypt the MPEG-2 source file from our video encoding test with the highest quality compression ratio. Secondly, we compressed and encrypted the folder of 400 photographs used in our Photoshop Elements test with the same compression settings.
Large File Compression & Encryption
WinRAR 3.71, Multithreaded, 276MB source file
  • Core i7 920 OC (4x4GHz, 1,600MHz DDR3, 3.6GHz QPI)
  • Core i7 965 (4x3.2GHz, Turbo disabled, SMT enabled)
  • Core i7 965 (4x3.2GHz, 6.4GHz QPI, SMT enabled)
  • Core i7 965 (4x3.2GHz, 4.8GHz QPI, SMT enabled)
  • Core i7 940 (4x2.93GHz, 6.4GHz QPI, SMT enabled)
  • Core i7 965 (4x3.2GHz, Dual Channel, SMT enabled)
  • Core i7 965 (4x3.2GHz, Single Channel, SMT enabled)
  • Core i7 920 (4x2.66GHz, 6.4GHz QPI, SMT enabled)
  • Core i7 965 (4x3.2GHz, 6.4GHz QPI, SMT disabled)
  • Core 2 Extreme QX9770 (4x3.2GHz, 1,600MHz FSB, DDR3)
  • Core 2 Extreme QX9770 (4x3.2GHz, 1,600MHz FSB, DDR2)
  • Core 2 Quad Q9650 (4x3.0GHz, 1,333MHz FSB, DDR3)
  • Core 2 Quad Q9550 (4x2.83GHz, 1,333MHz FSB, DDR3)
  • Core 2 Quad Q9650 (4x3.0GHz, 1,333MHz FSB, DDR2)
  • Core 2 Quad Q9450 (4x2.66GHz, 1,333MHz FSB, DDR3)
  • Core 2 Quad Q9550 (4x2.83GHz, 1,333MHz FSB, DDR2)
  • Core 2 Quad Q9450 (4x2.66GHz, 1,333MHz FSB, DDR2)
  • Core 2 Quad Q6700 (4x2.66GHz, 1,066MHz FSB, DDR2)
  • Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB, DDR3)
  • AMD Phenom X4 9950 BE (4x2.6GHz, 2.0GHz HTT)
  • Core 2 Quad Q6700 (4x2.66GHz, 1,066MHz FSB, DDR3)
  • Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB, DDR2)
  • AMD Phenom X4 9850 BE (4x2.5GHz, 2.0GHz HTT)
  • AMD Phenom X4 9750 (4x2.4GHz, 1.8GHz HTT)
    • 63
    • 69
    • 69
    • 69
    • 72
    • 72
    • 73
    • 78
    • 82
    • 93
    • 101
    • 103
    • 106
    • 108
    • 109
    • 111
    • 115
    • 123
    • 125
    • 130
    • 133
    • 133
    • 133
    • 135
50
75
100
125
150
Time in Seconds (lower is better)
  • Seconds
Small File Compression & Encryption
WinRAR 3.71, Multithreaded, 400 2048x1536 Photos
    • 58
    • 68
    • 68
    • 68
    • 70
    • 71
    • 73
    • 79
    • 81
    • 86
    • 86
    • 87
    • 90
    • 92
    • 95
    • 99
    • 99
    • 105
    • 109
    • 114
    • 118
    • 123
    • 126
    • 139
50
75
100
125
150
  • Seconds
In WinRAR, the overclocked Core i7 920 is six to ten seconds, or ten to 15 percent faster than the Core i7 965 and 24 to 40 percent quicker than the original Core i7 920 which is a huge gain. Compared to the previous generation, we're seeing significant and noticeable gains in compression times in the region of 20 to 30 seconds in this short test.
7-Zip
Website: 7-Zip
Our community requested the inclusion of 7-Zip, a free compression tool that is an alternative to WinRAR and we've obliged accordingly. Using the internal benchmark this measures compression and decompression performance in MIPS and provides an average result. It is multi-threaded so takes advantage of the latest multi-core and SMT enabled CPUs.
We left the benchmark to accumulate 10 runs using a 32MB Dictionary size in order to get a solid, average result.
7-Zip
Internal Benchmark
    • 22592.0
    • 18322.0
    • 17967.0
    • 17911.0
    • 16381.0
    • 15162.0
    • 12627.0
    • 12306.0
    • 12248.0
    • 12187.0
    • 11590.0
    • 11195.0
    • 11054.0
    • 10729.0
    • 10575.0
    • 10007.0
    • 9932.0
    • 9712.0
    • 9703.0
    • 9019.0
    • 8756.0
    • 8308.0
    • 6145.0
    • 6048.0
10000
15000
20000
25000
MIPS (higher is better)
  • MIPS
The 7-Zip performance scales wonderfully because it likes cores and memory bandwidth as much as it likes MHz. It has a 23 percent performance improvement over the Core i7 965 and is 49 percent faster than the i7 920 at stock speeds - virtually a 1:1 performance improvement with clock speed! What's impressive is that it's a massive 85 percent faster than the QX9770 here as well.
