Maxon Cinebench 10 x64
Website: Cinebench
Maxon Cinebench is based on Maxon's popular animation software, Cinema 4D, which is used extensively by studios and production houses worldwide for 3D content creation. We've used the built-in CPU benchmark, which uses a 3D scene file to render a photo-realistic image of a concept bike. The scene makes use of various CPU-intensive features such as reflection, ambient occlusion, area lights and procedural shaders.
Core i7 920 OC (4x4GHz, 1,600MHz DDR3, 3.6GHz QPI)
Core i7 965 (4x3.2GHz, 4.8GHz QPI, SMT enabled)
Core i7 965 (4x3.2GHz, 6.4GHz QPI, SMT enabled)
Core i7 965 (4x3.2GHz, Dual Channel, SMT enabled)
Core i7 965 (4x3.2GHz, Turbo disabled, SMT enabled)
Core i7 965 (4x3.2GHz, Single Channel, SMT enabled)
Core i7 940 (4x2.93GHz, 6.4GHz QPI, SMT enabled)
Core i7 965 (4x3.2GHz, 6.4GHz QPI, SMT disabled)
Core i7 920 (4x2.66GHz, 6.4GHz QPI, SMT enabled)
Core 2 Extreme QX9770 (4x3.2GHz, 1,600MHz FSB, DDR3)
Core 2 Extreme QX9770 (4x3.2GHz, 1,600MHz FSB, DDR2)
Core 2 Quad Q9650 (4x3.0GHz, 1,333MHz FSB, DDR3)
Core 2 Quad Q9650 (4x3.0GHz, 1,333MHz FSB, DDR2)
Core 2 Quad Q9550 (4x2.83GHz, 1,333MHz FSB, DDR3)
Core 2 Quad Q9550 (4x2.83GHz, 1,333MHz FSB, DDR2)
Core 2 Quad Q9450 (4x2.66GHz, 1,333MHz FSB, DDR3)
Core 2 Quad Q9450 (4x2.66GHz, 1,333MHz FSB, DDR2)
Core 2 Quad Q6700 (4x2.66GHz, 1,066MHz FSB, DDR2)
Core 2 Quad Q6700 (4x2.66GHz, 1,066MHz FSB, DDR3)
AMD Phenom X4 9950 BE (4x2.6GHz, 2.0GHz HTT)
AMD Phenom X4 9850 BE (4x2.5GHz, 2.0GHz HTT)
AMD Phenom X4 9750 (4x2.4GHz, 1.8GHz HTT)
Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB, DDR3)
Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB, DDR2)
10000
15000
20000
25000
2000
3000
4000
5000
6000
In Cinebench 10, the Core i7 920 overclocked affords a large 24 and 50 percent performance increment over the i7 965 and 920 at their native speeds respectively. Again we see a nearly 1:1 performance scaling with clock and memory speeds from the Core i7 920. In the single threaded test, the CPU still leads the table and still creates a healthy 44 percent improvement over its native clock speed that meant the CPU sat halfway down the table.
