Crysis
Publisher: Electronic Arts
Crysis is seen by many as the poster boy for DirectX 10 and it will make your system quite literally fall over crying if it's not up to – it’s a monster of an engine! It doesn’t come as much of a surprise then, that the graphics are something special – they’re above and beyond anything we’ve ever seen in a PC game even still. We used the latest 1.21 patch and range the game in 64-bit and DirectX 10 mode in a custom level run through.
Core i7 920 OC (4x4GHz, 1,600MHz DDR3, 3.6GHz QPI)
Core i7 965 (4x3.2GHz, 6.4GHz QPI, SMT enabled)
Core i7 965 (4x3.2GHz, Turbo disabled, SMT enabled)
Core i7 965 (4x3.2GHz, 6.4GHz QPI, SMT disabled)
Core i7 965 (4x3.2GHz, Dual Channel, SMT enabled)
Core i7 965 (4x3.2GHz, 4.8GHz QPI, SMT enabled)
Core i7 940 (4x2.93GHz, 6.4GHz QPI, SMT enabled)
Core i7 965 (4x3.2GHz, Single Channel, SMT enabled)
Core 2 Extreme QX9770 (4x3.2GHz, 1,600MHz FSB, DDR3)
Core 2 Extreme QX9770 (4x3.2GHz, 1,600MHz FSB, DDR2)
Core i7 920 (4x2.66GHz, 6.4GHz QPI, SMT enabled)
Core 2 Quad Q9650 (4x3.0GHz, 1,333MHz FSB, DDR3)
Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB, DDR3)
Core 2 Quad Q9650 (4x3.0GHz, 1,333MHz FSB, DDR2)
Core 2 Quad Q9550 (4x2.83GHz, 1,333MHz FSB, DDR3)
Core 2 Quad Q9450 (4x2.66GHz, 1,333MHz FSB, DDR3)
Core 2 Quad Q9550 (4x2.83GHz, 1,333MHz FSB, DDR2)
Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB, DDR2)
Core 2 Quad Q9450 (4x2.66GHz, 1,333MHz FSB, DDR2)
Core 2 Quad Q6700 (4x2.66GHz, 1,066MHz FSB, DDR2)
Core 2 Quad Q6700 (4x2.66GHz, 1,066MHz FSB, DDR3)
AMD Phenom X4 9950 BE (4x2.6GHz, 2.0GHz HTT)
AMD Phenom X4 9850 BE (4x2.5GHz, 2.0GHz HTT)
AMD Phenom X4 9750 (4x2.4GHz, 1.8GHz HTT)
Frames Per Second - higher is better
Four extra frames per second is what a 50 percent overclock gets you - not much, but it's still "free" performance and the fastest thing on the entire table by over a frame per second.
