Far Cry 2
Publisher: Ubisoft
Far Cry 2 is the latest first person shooter from Ubisoft, and while it continues the
Far Cry franchise that Crytek started in 2004, this game is built on its own in-house engine and has no association - other than its name - to anything Crytek has worked on or is working on now. We used a retail version of the game and the in-built gameplay demo set to High-Very High settings under DirectX 10.
Core 2 Extreme QX9770 (4x3.2GHz, 1,600MHz FSB, DDR3)
Core 2 Extreme QX9770 (4x3.2GHz, 1,600MHz FSB, DDR2)
Core 2 Quad Q9650 (4x3.0GHz, 1,333MHz FSB, DDR3)
Core 2 Quad Q9550 (4x2.83GHz, 1,333MHz FSB, DDR3)
Core 2 Quad Q9450 (4x2.66GHz, 1,333MHz FSB, DDR3)
Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB, DDR3)
Core 2 Quad Q9650 (4x3.0GHz, 1,333MHz FSB, DDR2)
Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB, DDR2)
Core 2 Quad Q9550 (4x2.83GHz, 1,333MHz FSB, DDR2)
Core 2 Quad Q9450 (4x2.66GHz, 1,333MHz FSB, DDR2)
Core 2 Quad Q6700 (4x2.66GHz, 1,066MHz FSB, DDR2)
Core 2 Quad Q6700 (4x2.66GHz, 1,066MHz FSB, DDR3)
AMD Phenom X4 9950 BE (4x2.6GHz, 2.0GHz HTT)
Core i7 920 OC (4x4GHz, 1,600MHz DDR3, 3.6GHz QPI)
Core i7 965 (4x3.2GHz, Turbo disabled, SMT enabled)
AMD Phenom X4 9850 BE (4x2.5GHz, 2.0GHz HTT)
Core i7 965 (4x3.2GHz, 6.4GHz QPI, SMT disabled)
Core i7 965 (4x3.2GHz, 6.4GHz QPI, SMT enabled)
AMD Phenom X4 9750 (4x2.4GHz, 1.8GHz HTT)
Core i7 965 (4x3.2GHz, Dual Channel, SMT enabled)
Core i7 965 (4x3.2GHz, 4.8GHz QPI, SMT enabled)
Core i7 940 (4x2.93GHz, 6.4GHz QPI, SMT enabled)
Core i7 920 (4x2.66GHz, 6.4GHz QPI, SMT enabled)
Core i7 965 (4x3.2GHz, Single Channel, SMT enabled)
Frames Per Second - higher is better
Again, even on another motherboard, we're seeing poor performance in
Far Cry 2, so at least we can rule out the motherboard and BIOS as a factor in this performance anomaly. The extra GHz and memory bandwidth generates a few FPS but not much - we suspect this is a driver issue, but neither Intel or Nvidia has commented to us about it yet.
