The Elder Scrolls V: Skyrim
Publisher: Bethesda
From our
The Elder Scrolls V: Skyrim review:
'It’s like watching Star Wars and genuinely thinking, ‘what about those poor Death Star construction workers?’ You’re missing the point: Skyrim is a huge and engaging world to explore and it treats you with great moments, from your first dragon encounter to finally being able to craft dwarven armour.'
We've updated our Skyrim benchmark to include the official high resolution texture pack, available as a free DLC. We set the game to its 'Ultra' setting and record a sixty second manual play through just outside the town of Whiterun during a thunderstorm. We use a section where we are able to run forward in a straight line for a minute without being attacked so the benchmark remains consistent, and use the third person camera view.
Many modern games make little use of the CPU, instead ploughing resources into the GPU, making the CPU’s impact on high-resolution performance difficult to test. As such, we’ve drafted in the Elder Scrolls: Skyrim, one of the easier games in our 3D benchmark suite, as well as a GeForce GTX 780 3GB to remove as many of the graphical limitations as possible. We’ve still tested at a meaningful resolution however, and with ultra-detail and high-resolution textures (although no AA).
Asus Maximus VII Impact (4.8GHz)
Asus Maximus VII Hero (4.8GHz)
Gigabyte GA-Z97X-SLI (4.7GHz)
Asus Gryphon Z97 (4.8GHz)
Gigabyte GA-Z97N-Gaming 5 (4.8GHz)
Asus Maximus VII Gene (4.8GHz)
MSI Z97 MPower (4.8GHz)
Asus Maximus VII Formula (4.8GHz)
MSI Z97S SLI Plus (4.8GHz)
MSI Z97M Gaming (4.8GHz)
Asus Z97i-Plus (4.8GHz)
Asus Maximus VII Ranger (4.8GHz)
ASRock Z97 Pro (4.8GHz)
ASRock Fatal1ty Z97 Killer (4.8GHz)
MSI Gaming 7 (4.8GHz)
ECS Z97-Machine (4.8GHz)
Asus Maximus VII Impact (stock speed)
ASRock Z97 Pro 3 (stock speed)
ASRock Fatal1ty Z97 Killer (stock speed)
Gigabyte GA-Z97N-Gaming 5 (stock speed)
MSI Z97 MPower (stock speed)
Asus Maximus VII Gene (stock speed)
Asus Z97i-Plus (stock speed)
MSI Z97M Gaming (stock speed)
MSI Gaming 7 (stock speed)
Asus Gryphon Z97 (stock speed)
Asus Maximus VII Formula (stock speed)
MSI Z97S SLI Plus (stock speed)
Gigabyte GA-Z97X-SLI (stock speed)
Asus Maximus VII Hero (stock speed)
ECS Z97-Machine (stock speed)
Asus Maximus VII Ranger (stock speed)
frames per second, higher is better
Total War: Shogun 2
Publisher:Sega
Total War games have been making grown PCs cry ever since the original Shogun was released in 2000. The many units, model animations, AI routines and the usual physics and object collision make Shogun 2 as hard a task to run for the CPU as the graphics card.
We use the built-in CPU test, launched by right-clicking on the game in your Steam library. This stages a scripted battle, where we watch the action at a reasonably zoomed-in level. We leave the detail settings at default and record the action for 60 seconds using FRAPS.
ASRock Z97 Pro 3 (4.8GHz)
Asus Maximus VI Hero (Z87) (4.7GHz)
Rightmark Audio Analyzer
Publisher: Rightmark
We've recently started testing motherboards using RightMark Audio Analyzer. We use the Playback/Recording test, first adjusting levels so they're within the benchmark parameters and then using 24-bit 192KHz tracks, we connect the line-in to the speaker/line-out jack using a standard 3.5mm audio cable.
Following feedback we felt it important to include some results given that onboard audio is a hotly fought-over area with motherboards at the moment. For comparison we've used an Asus P8Z77-I Deluxe, which features standard on-board Realtek ALC898 8-Channel High Definition Audio to represent a baseline for standard on-board audio.
ECS Z97-Machine
On-board Realtek ALC898 (benchmark)
Asus Gryphon Z97
Asus Z97i-Plus
MSI Z97S SLI Plus
ASRock Z97 Pro 3
Higher is better
ECS Z97-Machine
Asus Gryphon Z97
ASRock Z97 Pro 3
Asus Z97i-Plus
MSI Z97S SLI Plus
Lower is better (figures are negative)
Asus Z97i-Plus
ASRock Z97 Pro 3
Asus Gryphon Z97
ECS Z97-Machine
MSI Z97S SLI Plus
0.005
0.0075
0.01
0.0125
Lower is better
