Power Consumption
For the power consumption tests we aim to gauge real-world power draw. The power draw is measured via a power meter at the wall, so the numbers below represent the total system power draw from the mains, not the power consumption of a CPU itself. Measuring the power draw of any individual component in a PC is tricky to impossible to achieve. We used Prime95 to fully load the CPU.
Idle Power Consumption
For this test, we leave the PC doing nothing but displaying the Windows 7 desktop (with Aero enabled) for a few minutes and record the wattage drawn from the wall via a power meter.
Raspberry Pi (claimed power consumption)
Gigabyte BRIX S GB-BXi5H-5200 (Core i5-5200U)
Intel NUC Kit NUC5i3RYK (Core i3-5010U)
Intel NUC D54250WYK (Core i5-4250U)
Intel NUC DC53427RKE
Intel NUC D33217CK
Intel Core i3-3220
Watts, lower is better
Load Power Consumption
To generate a realistic load power consumption figure we load the CPU using Prime95's small FFT test, which mimics 100 percent load across all logical and physical cores.
Intel NUC D33217CK
Intel Core i3-3220
20
30
40
50
60
70
80
CrystalDiskMark Benchmark Results
Website: CrystalDiskMark
CrystalDiskMark is similar to AS SSD in its use of incompressible data files, although it does use a different data pattern. We report the read and write results of the sequential and 4KB random tests
Overclockers UK Infin8 Nebula
50
75
100
125
150
175
MB/sec, higher is better
PCMark 8 Storage tests
Website: Futuremark
We've selected two benchmarks from PCMark 8's array of storage tests - the Battlefield 3 and Heavy Photoshop storage traces. These mimic real-world usage, for instance, loading a game and entering a save game or performing image editing. The final result is given in seconds.
Seconds, lower is better
Ambros Gigabyte BRIX S GB-BXi5H-5200
