PCMark 8 Video Editing
Video Editing v2 Part 2 (Creative 3.0 test suite)
This workload uses
FFmpeg to apply video enhancement filters to a high bitrate H.264 video and then encode it to a format suitable for distribution. The FFmpeg binary used is custom built by Futuremark using a development version of the source available from the project's code repository. The test applies a deshaking filter to a source video at 3,840 x 2160 (4K UHD) before scaling down and outputting at 1,920 x 1,080 (1080p).
        Asus Z170i Pro Gaming (4GHz/4.8GHz)
        Asus Maximus VIII Hero (4GHz/4.8GHz)
        Asus Maximus VIII Gene (4GHz/4.8GHz)
        MSI Z170A XPOWER Gaming Titanium Edition (4GHz/4.8GHz)
        MSI Z170A Gaming Pro Carbon (4GHz/4.8GHz)
        Asus Z170-Deluxe (4GHz/4.8GHz)
        Gigabyte Z170X-Gaming 7 (4GHz/4.8GHz)
        MSI Z170I Gaming Pro AC (4GHz/4.6GHz)
        MSI Z170A Gaming M5 (4GHz/4.6GHz)
        MSI Z170A SLI Plus (4GHz/4.7GHz)
        Asus Maximus VIII Impact (4GHz/4.9GHz)
        Asus Sabertooth Z170 Mark 1 (4GHz/4.8GHz)
        Gigabyte Z170-Gaming K3 (4GHz/4.8GHz)
        Gigabyte Z170MX-Gaming 5 (4GHz/4.8GHz)
Seconds, lower is better
PCMark 8 Photo Editing V2
This workload involves making a series of adjustments to a set of photographs using
ImageMagik - an open-source image processing library to adjust brightness, contrast, saturation and gamma. When a favourable balance is found, the changes are then applied to the rest of the images in the set. TIFF files up to 67MB in size are used.
        MSI Z170A Gaming M5 (4GHz/4.8GHz)
SATA and M.2 Performance
Website: CrystalDiskMark
We test the SATA and performance with a Samsung SSD 850 PRO, as this is one of the fastest SSDs we've ever tested, and it can saturate the bandwidth of SATA 6Gbps ports.
For the M.2 port, we've upgraded our old Kingston KyperX Predator SSD to Samsung's SSD 950 Pro M.2 256GB NVMe SSD, which has a claimed throughput of 2,200MB/sec read and 900MB/sec write.
We've also updated to a newer version of CrystalDiskMark across both M.2 and SATA tests. We'll be adding to this graphs over time to include more results.
        MSI Z170A SLI Plus
          1000
          1500
          2000
          2500
    MB/sec, higher is better
        Asus Z170i Pro Gaming (Intel SATA 6Gbps)
        MSI Z170A Gaming Pro Carbon (Intel SATA 6Gbps)
        Asus Maximus VIII Formula (Intel SATA 6Gbps)
        Gigabyte Z170MX-Gaming 5 (Intel SATA 6Gbps)
        Gigabyte Z170-Gaming K3 (Intel SATA 6Gbps)
        Asus Maximus VIII Impact (Intel SATA 6Gbps)
        Asus Maximus VIII Formula (ASMedia 6Gbps)
          200
          300
          400
          500
          600
