Total War: Attila
Publisher: Sega
We use the built-in Londinium benchmark of Total War: Attila, which runs through an automatic play-through scene in the game. Go to Custom Settings and the benchmark tool is at the bottom. We turn off anti-aliasing and select the quality setting, with v-sync and SSAO disabled. We use Fraps to record a 50-second sequence from the start of the benchmark.
MSI Z170A MPOWER Gaming Titanium (4.7GHz)
Asus Maximus VIII Hero Alpha (4.8GHz)
MSI Z170A Gaming Pro Carbon (4.8GHz)
Gigabyte Z170MX-Gaming 5 (4.8GHz)
Asus Sabertooth Z170 Mark 1 (4.8GHz)
Asus Maximus VIII Impact (4.9GHz)
MSI Z170I Gaming Pro AC (4.6GHz)
MSI Z170A XPOWER Gaming Titanium Edition (4.8GHz)
Asus Z170i Pro Gaming (4.8GHz)
Gigabyte Z170X-Gaming 7 (4.8GHz)
Asus Maximus VIII Hero (4.8GHz)
MSI Z170A XPOWER Gaming Titanium Edition (Stock)
Gigabyte Z170N-Gaming 5 (4.8GHz)
Gigabyte Z170-Gaming K3 (4.8GHz)
MSI Z170A SLI Plus (4.7GHz)
Asus Maximus VIII Hero (Stock)
MSI Z170A MPower Gaming Titanium (Stock)
MSI Z170A Gaming Pro Carbon (Stock)
Gigabyte Z170MX-Gaming 5 (Stock)
Asus Sabertooth Z170 Mark 1 (Stock)
Asus Z170i Pro Gaming (Stock)
Gigabyte Z170-Gaming K3 (Stock)
Asus Maximus VIII Hero Alpha (Stock)
Asus Maximus VIII Impact (Stock)
Gigabyte Z170X-Gaming 7 (Stock)
Gigabyte Z170N-Gaming 5 (Stock)
MSI Z170A SLI Plus (Stock)
MSI Z170I Gaming Pro AC (Stock)
Frame per second
Unigine Valley 1.0
Publisher: Unigine
Unigine's free Valley 1.0 benchmarking tool works well as a graphics benchmark as it is GPU-limited and is thus incredibly taxing on the GPU whilst placing the CPU under very little stress. Unigine's scoring system is effectively linear: a card with 2,000 points is considered twice as fast as one with 1,000 points, and half as fast as one with 4,000 points. As such, you can easily replicate and run the test on your own system to gauge roughly how big a difference an upgrade would likely make for you.
MSI Z170A XPOWER Gaming Titanium Edition (4GHz/4.8GHz)
Asus Z170i Pro Gaming (4GHz/4.8GHz)
MSI Z170A Gaming Pro Carbon (4GHz/4.8GHz)
Gigabyte Z170X-Gaming 7 (4GHz/4.8GHz)
Asus Maximus VIII Hero Alpha (4GHz/4.8GHz)
Gigabyte Z170MX-Gaming 5 (4GHz/4.8GHz)
MSI Z170I Gaming Pro AC (4GHz/4.6GHz)
Asus Maximus VIII Hero (4GHz/4.8GHz)
Asus Sabertooth Z170 Mark 1 (4GHz/4.8GHz)
MSI Z170A SLI Plus (4GHz/4.7GHz)
Asus Maximus VIII Gene (4GHz/4.8GHz)
Asus Z170-Deluxe (4GHz/4.8GHz)
MSI Z170A MPOWER Gaming Titanium (4GHz/4.7GHz)
Asus Maximus VIII Impact (4GHz/4.9GHz)
MSI Z170A Gaming M5 (4GHz/4.6GHz)
Gigabyte Z170-Gaming K3 (4GHz/4.8GHz)
Gigabyte Z170N-Gaming 5 (4GHz/4.8GHz)
2000
3000
4000
5000
Score, higher is better
3DMark Fire Strike
Publisher: Futuremark
Fire Strike is a showcase DirectX 11 benchmark designed for today's high-performance gaming PCs. It is 3DMark's most ambitious and technical benchmark ever, featuring real-time graphics rendered with detail and complexity far beyond what is found in other benchmarks and games today.
Asus Maximus VIII Impact (4GHz/4.8GHz)
5000
7500
10000
12500
Seconds, lower is better
