Gigabyte Z170X-Gaming 7 Review
Written by Antony Leather
October 8, 2015 | 13:55
Tags: #best-skylake-board #best-z170-board #lga1151 #skylake #z170
Companies: #gigabyte
Total War: Attila
We've introduced the built-in Londinium benchmark of Total War's Attila, which runs through an automatic play-through scene in this demanding game. You can run the benchmark from Custom Settings and the benchmark tool is at the bottom. We turn off anti-aliasing and select the quality setting, with v-sync and SSAO disabled. We use Fraps to record a 50-second sequence from the start of the benchmark.
Total War: Attila
1,920 x 1,080, Quality settings
  • Gigabyte Z170X-Gaming 7 (4.8GHz)
  • Asus Maximus VIII Hero (4.8GHz)
  • Asus Maximus VIII Hero (Stock)
  • Gigabyte Z170X-Gaming 7 (Stock)
    • 60
    • 70
    • 60
    • 70
    • 59
    • 69
    • 57
    • 67
20
30
40
50
60
70
Frame per second
  • Min
  • Avg
Unigine Valley 1.0 Benchmark
Publisher: Unigine
Unigine's free Valley 1.0 benchmarking tool works well as a graphics benchmark as it is GPU limited and is thus incredibly taxing on the GPU whilst placing the CPU under very little stress. Unigine's scoring system is effectively linear: a card with 2,000 points is considered twice as fast as one with 1,000 points, and half as fast as one with 4,000 points. As such, you can easily replicate and run the test on your own system to gauge roughly how big a difference an upgrade would likely make for you.
Unigine Valley
1,920 x 1,080, High settings
  • Gigabyte Z170X-Gaming 7 (4GHz/4.8GHz)
  • Asus Maximus VIII Hero (4GHz/4.8GHz)
  • Asus Maximus VIII Gene (4GHz/4.8GHz)
  • Asus Z170-Deluxe (4GHz/4.8GHz)
  • MSI Z170A Gaming M5 (4GHz/4.6GHz)
    • 4831
    • 4942
    • 4815
    • 4914
    • 4786
    • 4920
    • 4769
    • 4943
    • 4751
    • 4893
2000
3000
4000
5000
Score, higher is better
  • Stock
  • Overclocked
3DMark Fire Strike
Publisher: Futuremark
Fire Strike is a showcase DirectX 11 benchmark designed for today's high-performance gaming PCs. It is 3DMark's most ambitious and technical benchmark ever, featuring real-time graphics rendered with detail and complexity far beyond what is found in other benchmarks and games today.
3DMark Fire Strike
Overall Score
    • 11307
    • 11363
    • 11237
    • 11459
    • 11112
    • 11193
5000
7500
10000
12500
Seconds, lower is better
  • Stock
  • Overclocked
3DMark Fire Strike
Graphics score
    • 4983
    • 4999
    • 4962
    • 4971
    • 4943
    • 4971
2000
3000
4000
5000
  • Stock
  • Overclocked
Posted by Hustler - Thu Oct 08 2015 14:07
All I can say is if you find the colour scheme appealing then there are lettuce leafs out there with more taste than you.
..It's all a bit 'Essex boy racer' Tiny Tom Logan for my liking.
Posted by SchizoFrog - Thu Oct 08 2015 15:25
Even Gigabyte seem confused. Is it 'G.1 Gaming' or 'Gaming 7'? Why not make it 'G.1 Gaming 7' and be done with it?
Also, every time I see that G.1 I think of G.I Joe and the crappy, remade movies...
Posted by ----jimbo---- - Thu Oct 08 2015 15:54
When reviewing Z170 boards can you please start specifying if they are HDMI 1.4 or 2.0. Twice during reviews I've had to go off to the manufactures page to find the specs.
Posted by Combatus - Thu Oct 08 2015 21:16
----jimbo----
We shall, as well as listing the manufacturer of the USB 3.1 controllers.
null
