Gigabyte GA-965P-DQ6
October 4, 2006 | 09:46
Tags: #965p #conroe #core-2 #crossfire #ddr2 #dq6 #esata #ga #ga-965p-dq6 #lga775 #p5b #p965 #quad #sata
Companies: #asus #gigabyte
Xvid Encoding:
We tested video encoding performance using VirtualDub-MPEG version 1.6.15 and a multithreaded version of the Xvid codec, along with the LAME MT MP3 encoder for encoding audio. We did a two-pass encode of a 15-minute 276MB digital TV recording with a target file size of 100MB.
Gigabyte GA-965P-DQ6 Multimedia Encoding
With the exception of DFI's Infinity 975X/G, the GA-965P-DQ6 is fractionally faster than the rest and is a whole five seconds faster than the Asus P5B Deluxe.
MP3 Encoding:
We used LAME MT for our audio encoding test - it's the multithreaded version of the popular LAME MP3 encoder. We ran tests with both Intel's and Microsoft's compilers - naturally, the Intel compiler resulted in some performance increases on Intel's processors. We converted all 18 tracks from Moby's popular Play album to a 192kbps variable bit-rate MP3.
Over the two tests, Gigabyte's GA-965P-DQ6 is a bit faster than the other boards we've compared it to.
Decoding suffers slightly and the DQ6 loses out by a couple of seconds against the fastest boards tested here. Using the Microsoft compiler, Gigabyte's P965 board performed the same as the Asus M2N32-SLI Deluxe WiFi Edition with an FX-62 installed.
