Publisher: Sierra
We regard
World in Conflict as one of the best real-time strategy games we've ever played.  It's based on Microsoft's DirectX 10 API and, in collaboration with Nvidia's
The Way It's Meant To Be Played developer support team, it incorporates some DirectX 10 specific graphics effects.
The first of these is a soft particle effect that removes the banding often found in particle effects like smoke, explosions, fire and debris - the effects simply didn't exist in the 3D world; instead, they were merely an add-on. With DirectX 10, the edges of the particle effects are much softer and banding is almost non-existent as the effects now interact with their 3D surroundings, as they're actually a part of the 3D world.
Additionally there are global cloud shadowing and volumetric lighting effects in the DirectX 10 version of the game.  The latter is often referred to as 'god rays' and its implementation in
World in Conflict interacts with the surroundings incredibly well.  On the other hand, the former is where clouds cast shadows on the rest of the environment and, because all clouds in
World in Conflict are volumetric and dynamic, the shadows cast by the clouds are rendered dynamically in DirectX 10 - they adjust in relation to the size, shape and orientation of the cloud in relation to the light source.
For our testing purposes, we used a full retail copy of the game and patched it to version 1.007, which includes a few fixes and some improved performance under DirectX 10.  We used a manual run through from the
Invasion level, which incorporates all of the effects we've discussed above.  We chose not to use the built-in benchmark because it's largely CPU-limited.  We used the "very high" preset, and controlled Anti-Aliasing and Anisotropic Filtering via the advanced settings tab.
        Nvidia GeForce GTX 280
        Nvidia GeForce GTX 260
        Nvidia Geforce 9800 GX2
        ATI Radeon HD 4870 X2
        ATI Radeon HD 4870
        Nvidia GeForce 9800 GTX+
        ATI Radeon HD 3870 X2
        ATI Radeon HD 4850
        Nvidia GeForce 8800 GT
        ATI Radeon HD 3870
    Frames Per Second
        ATI Radeon HD 4850
        ATI Radeon HD 4870
        ATI Radeon HD 3870
    Frames Per Second
        ATI Radeon HD 4870
        ATI Radeon HD 4850
        ATI Radeon HD 3870
    Frames Per Second
        ATI Radeon HD 4870
        ATI Radeon HD 4850
        ATI Radeon HD 3870
    Frames Per Second
        ATI Radeon HD 4870
        ATI Radeon HD 4850
        ATI Radeon HD 3870
    Frames Per Second
World in Conflict has a reputation for not delivering the greatest levels of scaling for multiple GPUs and that's one reason why we continue to leave it in our benchmark suite.  It's one game that keeps things honest and in this case, what we're seeing is normal - the Radeon HD 4870 X2 is confined to the upper middle of the pack right the way up until 2,560 x 1,600 2xAA 16xAF, where it and the GeForce GTX 280 start to pull out a bit of daylight between them and the rest of the pack.
But even here, the scaling isn't as good as it could be and so it's the GeForce GTX 280 that's the faster of the two.  And what's more, the raw performance improvement delivered as a result of adding that second RV770 GPU equates to about 27 percent at 2,560 x 1,600 2xAA 16xAF.  At every other setting, you'll see no more than a 10 percent performance increase - that's pretty dismal given the massive price increase.
