AMD Radeon R9 295X2 8GB - Overclocking
Using the Catalyst Control Centre to first increase the card's power threshold to 150 percent, we managed a core overclock of 9 percent, which gave us a maximum core speed of 1,109MHz. This is just short of the 1,120MHz we achieved with a single R9 290X, which is a decent result given that there are now two of them.
Our experience with memory overclocking was simply phenomenal, as the card was stable with the chips running at 1.65GHz (6.6GHz effective), which is a 32 percent increase over stock speeds – we only managed 5.6GHz on the stock R9 290X. Whether this is due to better memory chips, improved cooling or simply luck (or a combination) we cannot say, but it's an excellent result either way.
To test the impact, we used our 4K tests, as only these would have a chance of showing anything meaningful. We also ran the Unigine Valley 1.0 benchmark at 2,560 x 1,440, the higher 16:9 resolution available.
        AMD Radeon R9 295X2 8GB (OC)
        AMD Radeon R9 290X 4GB
        AMD Radeon R9 290 4GB
        Nvidia GeForce GTX Titan Black 6GB
          20
          30
          40
          50
          60
          70
          80
    Frames Per Second
        Nvidia GeForce GTX 780 Ti 3GB
Frames Per Second
        Nvidia GeForce GTX 780 3GB
          2000
          3000
          4000
          5000
    Score (higher is beter)
