Aorus GeForce GTX 1080 11Gbps Review
May 10, 2017 | 15:42
Tags: #gddr5x #geforce #gtx-1080 #pascal
Companies: #aorus #gigabyte #nvidia
Power Consumption (Idle and Gaming)
In order to get an idea of a GPU's power draw, we loop the Unigine Valley 1.0 benchmark (2,560 x 1,400, 'Ultra' detail, no anti-aliasing), which is a very GPU-limited test. We use a watt meter to measure the maximum total system power draw during the test, and also take an idle reading at the Windows desktop (3,840 x 2,160).
Power Consumption
Idle (Windows 10 Desktop) and Load (Unigine Valley 1.0)
  • Gigabyte GeForce GTX 1060 WindForce OC 3GB
  • Gigabyte GeForce GTX 1060 G1 Gaming 6GB
  • Sapphire Radeon RX 470 Nitro+ OC 4GB
  • Sapphire Radeon RX 480 Nitro+ OC 4GB
  • MSI Radeon RX 570 Gaming X 4GB
  • Palit GeForce GTX 1070 GameRock Premium Edition 8GB
  • Sapphire Radeon RX 480 Nitro+ OC 8GB
  • Asus Radeon RX 580 Strix Gaming Top OC 8GB
  • EVGA GeForce GTX 1080 FTW 8GB
  • Aorus GeForce GTX 1080 11Gbps 8GB
  • Nvidia GeForce GTX 1080 Ti Founders Edition 11GB
  • Nvidia Titan X Pascal 12GB
  • AMD Radeon R9 Fury X 4GB
  • Aorus GeForce GTX 1080 Ti 11GB
    • 68
    • 212
    • 71
    • 237
    • 80
    • 282
    • 75
    • 294
    • 75
    • 299
    • 72
    • 303
    • 76
    • 308
    • 91
    • 322
    • 74
    • 339
    • 73
    • 346
    • 74
    • 379
    • 70
    • 385
    • 83
    • 400
    • 76
    • 406
200
300
400
System Power Draw in Watts (lower is better)
  • Idle
  • Load
Thermal Performance (Idle and Gaming)
Thermal output is also measured using Unigine's Valley 1.0 benchmark. The GPU is installed in a closed, but fairly well ventilated case (Corsair Graphite 760T) with HDD cages removed and the case fans at full speed. We leave all GPU fan profiles and settings as they come and leave the benchmark running for ten minutes so that temperatures plateau. We record the peak GPU temperature using GPU-Z, and present the data as the delta T (the difference between the GPU temperature and the ambient temperature in our labs). We also take an idle reading at the Windows desktop (3,840 x 2,160).
Temperature
    • 5
    • 35
    • 16
    • 41
    • 19
    • 44
    • 19
    • 45
    • 22
    • 46
    • 16
    • 48
    • 23
    • 49
    • 25
    • 54
    • 20
    • 57
    • 22
    • 57
    • 12
    • 58
    • 26
    • 59
    • 18
    • 66
    • 17
    • 70
20
30
40
50
60
70
Delta T in °C (lower is better)
  • Idle
  • Load
