Aorus GeForce GTX 1080 11Gbps Review
May 10, 2017 | 15:42
Tags: #gddr5x #geforce #gtx-1080 #pascal
Companies: #aorus #gigabyte #nvidia
Aorus GeForce GTX 1080 11Gbps Overclocking
As we saw with the Aorus GTX 1080 Ti, this card allows you to increase its power limit to 150 percent, theoretically allowing the card to boost further – most partner Nvidia cards are limited to 120 percent or less here. You can also increase the temperature limit to 92°C.
With both settings at their maximum, we were able to add 200MHz to the GPU, which saw it boosting reliably to 2,037MHz and sometimes even 2,050MHz – a solid result. This was with the voltage slider in the Aorus Graphics Engine software set to the maximum amount, although this did not appear to actually make any difference.
The new, faster GDDR5X reached an impressive speed of 1.5125GHz for an effective speed of 12.1Gbps – a solid 10 percent boost.
Overclocking - 3DMark Fire Strike Extreme
2,560 x 1,440, DX11, default settings
  • Aorus GeForce GTX 1080 Ti 11GB
  • Nvidia GeForce GTX 1080 Ti Founders Edition 11GB
  • Nvidia Titan X Pascal 12GB
  • Aorus GeForce GTX 1080 11Gbps 8GB (manual OC)
  • Aorus GeForce GTX 1080 11Gbps 8GB (OC Mode)
  • Aorus GeForce GTX 1080 11Gbps 8GB (Gaming Mode)
  • EVGA GeForce GTX 1080 FTW 8GB
  • Aorus GeForce GTX 1080 11Gbps 8GB (Silent Mode)
  • Palit GeForce GTX 1070 GameRock Premium Edition 8GB
  • AMD Radeon R9 Fury X 4GB
  • Asus Radeon RX 580 Strix Gaming Top OC 8GB
    • 12909
    • 12302
    • 12284
    • 10920
    • 10437
    • 10410
    • 10133
    • 10041
    • 8679
    • 7450
    • 6095
5000
7500
10000
12500
15000
Score
  • Score
Overclocking - Battlefield 1
2,560 x 1,440, DX12, 'Ultra' settings
  • Aorus GeForce GTX 1080 11Gbps 8GB (OC)
    • 78
    • 85
    • 74
    • 82
    • 72
    • 81
    • 67
    • 74
    • 64
    • 70
    • 62
    • 68
    • 55
    • 59
    • 45
    • 50
    • 39
    • 44
20
30
40
50
60
70
80
90
Frames Per Second
  • Minimum
  • Average
Overclocking - The Witcher 3: Wild Hunt
2,560 x 1,440, DX11, 'Ultra' settings (HairWorks off)
    • 94
    • 103
    • 89
    • 100
    • 88
    • 98
    • 78
    • 86
    • 72
    • 80
    • 71
    • 80
    • 59
    • 67
    • 50
    • 57
    • 42
    • 47
50
75
100
Frames Per Second
  • Minimum
  • Average
