ASUS GeForce GTX 760 MARS Review - Overclocking
Using the Asus GPU Tweak software, we began by raising the card's power target to 105 percent and the temperature target to 95°C, the maximum allowed in both cases.
We settled on an overclock of 1,127MHz on both cores (the GPU Tweak software automatically overclocks them both together). This is equal to a 12 percent (121MHz actual) overclock, which isn't the best we've ever seen but still isn't bad, especially for a dual GPU card. The reported boost clock at this level was 1,192MHz, but it actually more commonly sat at 1,254MHz under load, which is excellent.
For the memory, we were able to push it from 6GHz effective to 6.5GHz effective, which is an 8 percent speed bump. The impressive results of these overclocks can be seen in the graphs below.
        AMD Radeon HD 7990 6GB
        ASUS GeForce GTX 760 MARS 4GB (OC)
        Nvidia GeForce GTX 690 4GB
        AMD Radeon R9 290X 4GB
        AMD Radeon R9 290 4GB
        Nvidia GeForce GTX 780 Ti 3GB
        Nvidia GeForce GTX Titan 6GB
    Frames Per Second
    Frames Per Second
          1000
          1500
          2000
          2500
          3000
          3500
    Score (higher is better)
