Power Consumption (Idle and Gaming)
In order to get an idea of a GPU's power draw, we run our Unigine Valley 1.0 benchmark, which is our most GPU limited test. We use a watt meter to measure the maximum total system power draw during the test, and also take an idle reading at the Windows desktop (2,560 x 1,440).
Nvidia GeForce GTX 750 Ti 2GB
AMD Radeon R7 260X 2GB
Nvidia GeForce GTX 660 2GB
MSI GTX 960 Gaming 2G 2GB (factory overclocked)
AMD Radeon R9 270 2GB
AMD Radeon R7 265 2GB
AMD Radeon R9 270X 2GB
Nvidia GeForce GTX 760 2GB
AMD Radeon R9 285 2GB
Nvidia GeForce GTX 980 4GB
AMD Radeon R9 280 3GB
MSI GTX 970 Gaming 4G 4GB (factory overclocked)
Asus Strix GTX 980 OC 4GB
Asus GTX 980 Poseidon Platinum 4GB
Nvidia GeForce GTX 770 2GB
Galax GTX 980 SOC 4GB
Gigabyte GTX 980 G1 Gaming 4GB
AMD Radeon R9 280X 3GB
Nvidia GeForce GTX 780 3GB
Nvidia GeForce GTX 780 Ti 3GB
Nvidia GeForce GTX Titan Black 6GB
AMD Radeon R9 290 4GB
AMD Radeon R9 290X 4GB
AMD Radeon R9 295X2 8GB
200
300
400
500
600
700
System Power Draw in Watts (lower is better)
Thermal Performance (Idle and Gaming)
Thermal output is also measured using Unigine's Valley 1.0 benchmark, as its DirectX 11 features will stress all parts of a modern GPU. We leave all GPU fan profiles and settings as they come and leave the benchmark running for ten minutes so that temperatures plateau. We record the peak GPU temperature using GPU-Z, and present the data as the delta T (the difference between the GPU temperature and the ambient temperature in our labs). We also take an idle reading at the Windows desktop (2,560 x 1,440).
Asus GTX 980 Poseidon Platinum 4GB (Water-cooled)
20
30
40
50
60
70
80
Delta T in °C (lower is better)
*As we do not have stock samples of the Nvidia GeForce GTX 970 or GTX 960, or the AMD Radeon R9 280X, R9 285, R9 280, R9 270 or R7 265, they are not included in the thermal performance graphs.
